DS2 bulbs
Old Oct 14, 2010 | 12:35 PM
robyn402's Avatar
DS2 bulbs
so i'm looking at picking up some HID's from DDM tuning
currently planning on getting a 8000k 55w kit for the low beams but using DS2 bulbs instead of 9006
anyone know if they fit in the housing?
Old Oct 14, 2010 | 12:36 PM
chazyronnie's Avatar
try xtralights.com
Old Oct 14, 2010 | 12:51 PM
robyn402's Avatar
..... appriciate the added option but i'd rather know if a DS2 will fit where a 9006 should go
Old Oct 14, 2010 | 02:42 PM
sstevojr's Avatar
Assuming you are intending to place HID bulbs in a Halogen style housing, NO!!!! speaking from experience its not a good idea to do this, it will inevitable cause a fire. For me, I didn't believe what I was told (go figure, right, haha) and decided to test it out for myself with a 20 min ride. When I stopped to check both my fog-lights had cracked all the way through from the additional heat output
Old Oct 14, 2010 | 02:44 PM
sstevojr's Avatar
also, the D2S bulbs cant clip into a 9006 housing; then there is the issue of power, that doesn't connect either.
Old Oct 14, 2010 | 02:45 PM
Bergen Automotive's Avatar
It wont work, we are a HID wholesaler, the d2s will not fit in a 9006 housing,
Old Oct 14, 2010 | 03:09 PM
robyn402's Avatar
good to know, just ordered up a 55w 9006 kit for my RA, though the bulb list says 9006 for 08 lancers... is the bulb the same for RA HID low beams?..
Old Oct 14, 2010 | 04:09 PM
initial_d2k's Avatar
do u have factory HID? if u do ... all u need is D2S 8000k bulb... (not a kit)
therefore 9006 wont work for a OEM HID equipped RA
Old Oct 14, 2010 | 10:01 PM
robyn402's Avatar
son of *****.... yea my ra comes stock with HIDS, i'm getting a kit because i'm upgrading to a 55w set up
Old Oct 14, 2010 | 10:16 PM
thats not gonna work..
1 - 9006 wont fit in ur OEM bulb socket
2 - u need D2S 55w
3 - even if u get D2S 55w, u need to *replace* ur OEM ballast ... which i think is really stupid.. (no offense)
my advice is ... get a H11 bulb from the same company and put the kit in ur fog ..
otherwise, sell it or return it..
Old Nov 27, 2010 | 10:11 AM
SharkyPR's Avatar
All right guys my RA came with Oem HiD.
What is the best HID bulb I can get that doesn't need to modify or change any other hardware just the bulb?
Old Nov 27, 2010 | 10:45 AM
i recommend Garax from iJDMToys
Old Nov 27, 2010 | 01:02 PM
sstevojr's Avatar
Check out lightwerkz, they have everything you need. I also have stock HID's and just ordered a new pair of 6000K 35w DS2
Old Nov 27, 2010 | 03:04 PM
SharkyPR's Avatar
All the HID mentioned above are direct bolt on without any further modification?
Just remove the stock one and replace with the new one?
Old Nov 27, 2010 | 04:08 PM
c2g's Avatar
c2g
i'm assuming that you want to go with the 55w ballast because it would be brighter then the 35w ballast but wouldn't last as long. the 8k bulbs will be more to the blue side which wouldn't as bright compared to a 4300k bulb (yellow whiteish). If I had projectors, I would go with the d2s 4300k bulb or 5000k (a little blue to it) and a 55w ballast to get the brightest output as possible and let the projectors will do the blue/purple flickering
I will be ordering the s2k-r projectors from the retrofitsource as soon as they come out with it and do a retrofit.
