just got a perfect exhaust for my RA
Old Jan 3, 2011 | 03:19 PM
  #46
ODUB's Avatar
looks good, now you need to get the car aligned.
Old Jan 3, 2011 | 03:26 PM
  #47
hansmitchel's Avatar
Thanks,
what do you mean by get the car aligned? Lowered?
If lowered, unfortunately I can't because of my steep driveway
Old Jan 3, 2011 | 09:35 PM
  #48
S2K2EVO's Avatar
Video sounds good thanks for posting. If you have time I would really like to hear an in car video. Windows up windows down, driving around and revving inside.
Old Jan 4, 2011 | 10:30 AM
  #49
nunyas's Avatar
I do like the sound of that... sounds much better than the original video posted. The original sounded almost stock. This video sounds a bit more aggressive; but not obnoxiously loud...
I ~think~ I might go for this instead of the UR cat back when i get my tax returns...
Old Jan 4, 2011 | 10:56 AM
  #50
SudzRA's Avatar
Originally Posted by hansmitchel
Finish is nice
Clearance...this was an issue I had. Tail shaft rubbed with exhaust but seems to be all good now after I readjusted everything. loosen the bolts and played with the exhaust pipe, then tighten them. Cable tied the exhaust so there is not much movement. No rubbing anymore. Sound is just great
Needed to make sure hangers are tight
Nice. As long as it fits properly after all is said and done without needing to modify the exhaust itself. That's what I wanted to hear.
I had a magnaflow on my last car that fit well, but not perfectly. The way it was bent caused it to hang lower than I wanted, and I had to have another hanger installed to bring it up. This fixed the clearance issue, but sometimes it would touch the rear bumper and rattle. Found out that the part of the hanger the the rubber mount hung on was about 1 inch too long, so the exhaust would slowly slide from one end of the hanger to the other, which brought the muffler tip backwards and upwards until was in contact with the bumper. I'd push it back straight again and it would be okay for a while, but eventually it would creep back up towards the bumper again. Oh and there was a trim screw above the muffler tip that was holding my rear lip on, and of course the muffler tip would hit the screw so I'd get a nice metallic buzz and a worn spot on the tip.
Now I know to ask before I decide to buy something
Old Jan 4, 2011 | 06:18 PM
  #51
junior_1810's Avatar
Very nice exhaust bro!!!
Old Jan 4, 2011 | 06:19 PM
  #52
Are those the oem fender vents??
Old Jan 4, 2011 | 06:30 PM
  #53
In car sound with windows up
In car sound with windows down
Old Jan 4, 2011 | 06:50 PM
  #54
chazyronnie's Avatar
^^ this exhaust have no drone at all and its not too loud than other aftermarket catback...
A loud exhaust is nice but after awhile you will get tired of it especially after too many fix up ticket from cops DC FTW!
Old Jan 4, 2011 | 07:51 PM
  #55
S2K2EVO's Avatar
Thanks for the quick post on the videos! That sounds really good, that isn't loud at all and I like that it doesn't have any drone at all from what I can tell. Seems like a nice aggressive tone without being over bearing.
Did you feel a good increase in power even without a tune?
Old Jan 4, 2011 | 07:57 PM
  #56
oh yeah definitely the increase in torque is very surprising just raced g37 last night and smoke him badly . you will feel the additional power for sure
Old Jan 5, 2011 | 08:19 AM
  #57
akj237's Avatar
hansmitchel, Thanks for taking the time to make these clips. You should get some sort of commision from DC Sports.
Old Jan 5, 2011 | 11:56 AM
  #58
nunyas's Avatar
watched the videos and was thinking that your glove box is on the wrong side of the car....
then I noticed you're in Australia
Old Jan 5, 2011 | 01:08 PM
  #59
jcm308's Avatar
I didn't even pick up on that LMAO.......
Where in Aus are you mate? Any chance you're in Sydney?
Old Jan 5, 2011 | 01:21 PM
  #60
yeah right hand drive for the Aussie's like in japan...
