P0140
Old Dec 15, 2010 | 07:07 PM
08Lancer89's Avatar
Exclamation P0140
Hey guys
I know theres alot of talk about this code but I havnt found a clear fix. I keep getting it even with the ams spacer right now I gave the fitting with the smallest hole and steel wool but it still comes up. I just want that stupid SES light gone it's annoying any ideas?
Old Dec 15, 2010 | 08:07 PM
GRAPHITE RALLI's Avatar
Originally Posted by 08Lancer89
Hey guys
to be honest you might be overdoing it, that code is triped for two reasons, one is the switch count per minute is to similar to the front AF sensor and the second is its not switching at all, you may be suffocating the sensor and tripping the code...just my .02
Old Dec 15, 2010 | 08:36 PM
Westbound&down's Avatar
regardless of it throwing or not, it is meaningless performance wise, and unless the light really bugs you i wouldnt worry about it.
Mine has been on for 6 months now, i clear it now and then, but its just useless.
Old Dec 15, 2010 | 10:53 PM
RazorLab's Avatar
Can be fixed with proper ECU tweak/tune.
Old Dec 16, 2010 | 06:28 AM
while its true it wont affect performance, theirs only one light and if its constantly on for some stupid reason like a p0140 code, you wont know if another more serious code has also been tripped
also this link explains that a po140 is caused from a lack of signal to the pcm http://www.obd-codes.com/p0140..
i would try removing the steel wool, then if its still a po140 increase the hole in the spacer until it goes away
Old Dec 16, 2010 | 07:06 AM
mikesim's Avatar
I was reading the relavent threads about deleting that code and its way over my head. I was hoping there would be a tune with those cel trips already removed.
Old Dec 16, 2010 | 09:26 AM
Mia_RA's Avatar
I had the smallest hole on my TurboXS test pipe and it never went away i would clear it and 4 or 5miles later it would pop back up. I switched to the medium sized hole and it cleared itself before i even made ti to a buddies house to have it cleared.
Old Dec 16, 2010 | 09:28 AM
RazorLab's Avatar
Will be part of V3.
Old Dec 16, 2010 | 12:36 PM
08Lancer89's Avatar
I'm going to try this. U just have a straight test pipe correct? Mines not resonated or anything.
Old Dec 17, 2010 | 10:33 PM
08Lancer89's Avatar
Still getting the code even with the biggest hole spacer in the o2 spacer.
Old Dec 18, 2010 | 06:41 AM
you might have a failed o2 sensor, take the spacer out and put the o2 sensor directly in the test pipe, if its still a po140 chances are good the o2 sensor went bad
Old Dec 18, 2010 | 07:49 AM
hotshot1's Avatar
i had this code too and i had the spacer and could never to get it to go away. but once i installed my evo x turbo magically it was gone. every once and a great while it comes back and then goes awat by itself again its weird
Old Dec 18, 2010 | 09:53 AM
08Lancer89's Avatar
I will try this Thanks for the heads up.
Old Dec 18, 2010 | 11:31 AM
NFSLancerRA's Avatar
Evil03 has a solution for this. I can't remember where he posted it.
Old Dec 18, 2010 | 05:51 PM
08Lancer89's Avatar
See if you can find it for me. Im talking to ams they turned off this code but it still throws it I'm confused.
