I just had to share this guys!!!
I love being BOOSTED and having a booster controller, for two days now I lowered the boost to 8PSI and im getting 33mpg, and getting 25mpg with out even trying, I love this!!! BOOST for life guys!!, Boost for life!!!! Saying this cause you can lower for the MPGs and you can up it for speed, But the sad thing is I have a manual one at the moment, but 3/4 on saving for a AEM Truboost gauge, so that i could control the BOOST levels from inside the Cabin
THAT IS ALL I HAVE TO SAY!!!, O AND OFCOURSE BEING AMONGST ALL YOU FINE PPL IS A PLUS TOO!!!!
just sayin'.
^^^hahah no im just excited i found this out.. guess rather late, but the gas was killing me till i did this, now my wallet is staying full!!!
I hate to burst your bubble, but lowering maximum boost isn't going to change fuel economy at cruise. If lowering the boost helps lighten up your right foot then I'm sure you've seen benefits at the pump. Leave it turned up and keep your foot out of it and you get the best of both worlds
Tom
Tom
Tom
Tom
Tom
Tom
I get 33 mpg on the highway with my evo x turbo 28 psi and 320 whp.
Turning your boost down on the stock tune is just making you run rich. Id love to see actual fuel consumption and not what the inaccurate indash tells you.
i like to have nice hp, and good fuel eco, obviously they both dont go hand in hand, but whats the difference between setting your 30psi to 10psi from mashing the gas pedal and only pressing it 1/4 way? lol
i dont see the need to turn down boost if i can drive w/o being IN boost.
cause at higher boost im noticing the throttle play is alot higher, meaning when at 8psi im less likely to mash it. seems liek when i 1/4 push the pedal at 8 there is less gas being used then say 1/4 at 21psi, obviously watching the speedameter a 1/4 at 8 doesn't move it much compared to having to much play at 1/4 with 21PSI
Tom
Tom
Closed for misinformation.
