Display?
Old Mar 3, 2011 | 12:43 PM
pbassist12's Avatar
Display?
http://www.arkdesign-us.com/mfd-multi-function-dash
Any one have this? Debating if i should get this or not vs getting gauges
Old Mar 3, 2011 | 12:50 PM
SudzRA's Avatar
Be sick if you could get that in a double DIN size and install it like a nav system
Old Mar 3, 2011 | 01:48 PM
velocityhead's Avatar
You CAN do that with EvoScan and an in-dash carputer...it's on my long to-do list.
Old Mar 3, 2011 | 04:05 PM
pbassist12's Avatar
I'm not sure how good this is compared to having gauges. Just want to see if someone has it And is the install easy?
Old Mar 3, 2011 | 04:30 PM
robyn402's Avatar
so this is what the guy from ARK told me
Base on the EVO X for the MFD:
Here is what is can read out of the box:
Injectors
RPM
Water Temp Sensor Signal
Throttle Sensor Signal
Vehicle speed
Boost
Optional Sensor:
Oil Temp
Oil Press
Water Temp
Base on the EVO X for the MFD II
Speed
RPM
Water Temp
Throttle
O2
Optional Sensor
Boost
Oil Temp
Oil Press or Water Temp (can only pick one)
Here is a link to the ARK Design Product Support pages for more info on the MFD and MFD II.
http://www.arkdesign-us.com/technical-support
so if you bought the MFD2 in order to read oil temp, oil pressure or boost you'd need to buy the following accessories
http://www.arkdesign-us.com/online-s...2-boost-sensor
http://www.arkdesign-us.com/online-s...ressure-sensor
http://www.arkdesign-us.com/online-s...erature-sensor
http://www.arkdesign-us.com/online-s...sensor-adapter
http://www.arkdesign-us.com/online-s...11/meter-stand
so all in all if right off the hop you wanted boost and A/F you'd be out about $500,
which is comparable to buying a gauge pod and gauges say you went with AEM for gauges figure round $400 ish all said and done.
you can always buy the extra sensor as you go, i like this idea cause it keeps all your info in one spot with out having to have gauges everywhere
Old Mar 3, 2011 | 05:08 PM
Answer_1's Avatar
If you have an Android device, you can get the Torque App which displays even more stuff than this...
Old Mar 3, 2011 | 06:40 PM
robyn402's Avatar
but how reliable/accurate is the app
Old Mar 3, 2011 | 06:52 PM
Answer_1's Avatar
Yep!
Check it out at http://torque-bhp.com
I have it and it's awesome! Can even tell you CEL codes and their meanings, and erase them.
Old Mar 3, 2011 | 07:21 PM
robyn402's Avatar
can it read A/F and oil temps or pressure?
Old Mar 3, 2011 | 07:33 PM
pbassist12's Avatar
I have the galaxy s With android. Is it hard to install? Hoe accurate is it?
Old Mar 4, 2011 | 06:34 AM
Answer_1's Avatar
It can read about whatever readings are available on the OBD2 port. Pretty accurate.
It also supports customs PID, so if something isn't buit in, you can add it. It a work in progress so the developper is adding new stuff quite often.
Very easy to install, it's in the market (free and paid version). All you need is a bluetooth dongle for the OBD2 port.
Old Mar 4, 2011 | 10:48 AM
pbassist12's Avatar
how much is the bluetooth dongle ?
Old Mar 4, 2011 | 11:28 AM
Answer_1's Avatar
You can get some on Ebay for about 40 bucks. PLX Devices also has one, which I think is about 100 bucks.
Old Mar 4, 2011 | 11:33 AM
EyeDreamt's Avatar
The problem with that app and OBDII for gauges is its a slow protocol not meant for real-time data like you want. Really your best option is indeed gauges or what velocityhead said, a carPC.
Something like this. I'm going out to install it now. I'll let ya know how it goes.
Old Mar 4, 2011 | 12:56 PM
pbassist12's Avatar
Let me know how it works and the pricing and stuff!
