had an thought about an evo x turbo swap
Old Mar 6, 2011 | 08:52 PM
newmitsuowner's Avatar
if i was to buy a brand new evo x turbo and had mitsubishi install it, then there would be no way i could void my warranty. is this correct?
Old Mar 6, 2011 | 09:01 PM
nyczlegacy's Avatar
with going that route the cost will probably exceed the cost of upgrading to an evoX and i still think your warranty will be gone unless youre tight with your dealership..
Old Mar 6, 2011 | 09:53 PM
robyn402's Avatar
that would definitely be a touchy subject and something you'd have to get in writing...
and since you'd have to reprogram your ecru that there would technically void your powertrain warranty
Old Mar 6, 2011 | 10:16 PM
GearDownSon's Avatar
This
Old Mar 7, 2011 | 03:20 AM
total0wnage's Avatar
I already thought of this a long time ago, I'm friends with the service department and they said no cause though it's a genuine Mitsubishi part, it didn't come that way from the factory and ecu mods is a auto void
Old Mar 7, 2011 | 03:37 AM
KX250Fmotoracer's Avatar
BS it wouldn't void warranty
Old Mar 7, 2011 | 05:16 AM
I wish
Old Mar 7, 2011 | 06:55 AM
why would it void it? they are installing it. doesn't it say in the manual you can only use genuine mitsu parts. i dont see anywhere in the manual that says that you cant
Old Mar 7, 2011 | 07:14 AM
velocityhead's Avatar
Installing a different turbo isn't as much of an issue as the modification of the ECU (reflashing)
Old Mar 7, 2011 | 08:01 AM
RideSober's Avatar
+1 This pretty much sums it up.
Look in your warranty manual under What is Not Covered, and then take a look at what is listed under Alteration, Misuse, or Accident Damage.
You will see they specifically mention altering or modifying the software programming.
My dealer is pretty good to work with and told me they are generally OK with most bolt on mods like exhaust or intakes and that the only warranty impact would be that those aftermarket parts would just not be covered. But he cautioned that if I have a warranty claim and they found that the software had been changed that would cause big problems. He was not too specific, but indicated the regional Mitsubishi rep was not at all tolerant of reflashing the ECUs.
Old Mar 7, 2011 | 10:15 AM
Im sure they would let us do it if there was a certified mitsubishi tuner or something lol. dealership starts tuning cars
