Best way to control boost?
Old Mar 25, 2011 | 08:52 AM
yancy21usa's Avatar
Hey guys was just wondering I'm planning on doing a custom dyno tune and looking for my peak boost to be at 25lbs. What's the best way to handle that boost? A boost pill upgrade or the 3 port boost controller?
Old Mar 25, 2011 | 09:01 AM
vanilla2's Avatar
Personally I'm looking at a 3 port to control my boist, but who knows if that's the best route consider how untamable boist can be sometimes.
Old Mar 25, 2011 | 09:16 AM
Mad_SB's Avatar
You should probly ask your tuner that question since not all tuners like all forms of boost control.
I'm running a 3port and hitting 21.5psi at about 65% duty cycle.... I just have to ask though why you are so set on running 25psi?
Old Mar 25, 2011 | 10:15 AM
sstevojr's Avatar
^ya, 25 psi on the stock snail is way excessive, not very safe for the long term. You would need to really speed up that tiny compressor wheel to hit 25psi, way risky imho
Old Mar 25, 2011 | 10:26 AM
evil03's Avatar
stock turbo will not do 25psi....
Old Mar 25, 2011 | 10:29 AM
wmplaya1352's Avatar
i'm sorry but i believe the stock turbo will hit 30 PSI
Old Mar 25, 2011 | 10:44 AM
omegis's Avatar
Stock turbo will do 25 psi. Albeit doesn't mean it's the safest in the long run if live @ the track.
Old Mar 25, 2011 | 10:59 AM
evo 9 guy's Avatar
Edit, just realized you drive a RA. Not sure in that case.
Old Mar 25, 2011 | 09:15 PM
zebra4's Avatar
I have GST pill and V2.5 tune. My boost will hit 25 psi and taper to around 23 or 24. Its a pretty reliable way to make power. I have never had a boost controller so my opinion is biased.
Old Mar 26, 2011 | 04:17 AM
03chi-town0Z's Avatar
The stock turbo will do 25psi and beyond, at low rpm and low flow requirements. It definitely won't hold that pressure for long, though.
Old Mar 26, 2011 | 05:22 AM
yancy21usa's Avatar
Well my tuner said he didnt even need a boost pill or anything and that they make peak boost 23lbs, but i thought 25psi peak boost couldnt hurt it that much. I drive my car about 3 times a week and not even hard so thats why i wasn't worried about so much boost. Everyone is always complaining how with out the boost pill the car boost isnt smooth and jerky sometimes. I just really want to know if a boost pill will aloow it to make better numbers.
Old Mar 26, 2011 | 09:53 AM
baggelis's Avatar
if you have a tc-sst do ecu controlled boost i went the manual boost controller way and i dont like it very much so im gonna be switching over soon
Old Mar 28, 2011 | 01:29 PM
spider21's Avatar
3 Port for sure and let the ECU do the control so there is no issues... 25psi is a little excessive on the stock Ralliart turbo. I am running 26psi on the Evo turbo after the swap.
Old Mar 28, 2011 | 01:40 PM
10Sportback's Avatar
After my tune last week and he said he maxed out my boost and now the computer thinks I'm running 26lbs max. I was running logs with AP, and this was after I changed out the stock boost pill for the AMS.
Old Mar 28, 2011 | 01:50 PM
RazorLab's Avatar
The stock turbo will do 25+ on the low end no problem.
When I still had the stock turbo I ran it up to 27psi in testing with more room to spare.
It will give you a torque hit, that's about it. Up top you don't want to run more then 12-13psi (and it won't do much more then that) or you will create way too much heat. With the stock FMIC you need to be very careful with spinning the turbo too much up top as the stock FMIC is totally useless with anything much more then stock boost and the added heat without the ability to shed it will cause detonation.
EvoooB
Feb 27, 2017 05:59 PM
backyardevo8
Jun 15, 2016 03:44 PM
Chamama
Nov 6, 2012 09:01 AM
BeyondLimitsEvo
Northeast Region
Jan 30, 2012 09:38 AM
2highpsi
Apr 21, 2008 07:10 AM
