tactrix
a tactrix cable is a device that allows communication between your laptop and your ECU. It is not mod specific. If you are referring to the GST Basemaps, then the answer is no. The basemaps are not designed to operate in a safe AFR range when an aftermarket intake is installed.
someone told me that if u go to mitsubishi u can buy the evox maf housinig for 60 bucks and put on the aftermarket intake and u will be able to do that what do u think???
https://www.evolutionm.net/forums/09...f-dummies.html
https://www.evolutionm.net/forums/09...ap-thread.html
https://www.evolutionm.net/forums/09...materials.html
