24,000km Serivce Question
Old Apr 12, 2011 | 01:38 PM
ArtofRalli's Avatar
I just reached 24,000 for m 2009 ralliart and will be doing the interval service soon.
I would like to confirm the pricing for this. For an oil change, brake inspection ect, tire rotation (the tire rotation i dont need) is $189.00.
Rear differential fluid change is recommened by the dealer @ 24,000km is $200.00
$189.00 + $200.00 = $439.57 with HST(tax)
Is this accurate and has everyone changed there rear diff fluids at 24,000 km,s?
Any input is appreciated !
Old Apr 12, 2011 | 02:34 PM
RazorLab's Avatar
Just FYI, if you can change the motor oil, you can change the rear diff oil.
I can understand if you don't want to but it's a piece of cake and will save you a very good amount of cash.
Old Apr 12, 2011 | 03:02 PM
2muchboost's Avatar
+1
I changed my motor oil for the first time a few months back and now im kicking myself for not doing it sooner. So much money wasted on such a simple job.
Old Apr 12, 2011 | 05:51 PM
jkennedy293's Avatar
It is a piece of cake to do it yourself. All you need is a 24mm wrench (a socket won't fit between the diff and the crossmember) and a 10mm allen wrench. It is actually easier than changing the engine oil since there is more room under the back of the car, and you don't have to remove any pesky covers. The transfer oil is just as easy to do yourself as well
Just make sure the car is level, so you put in the proper amount of fluid.
Old Apr 12, 2011 | 08:00 PM
xi's Avatar
xi
Does anyone have the service manuals showing where things are?
Old Apr 13, 2011 | 03:55 AM
initial_d2k's Avatar
im reaching the same service interval in a month or 2, I was wondering what aftermarket replacement can I use instead of the DiaQueen?
The manual stated Transfer Oil (for LSD) and thats it?
Old Apr 13, 2011 | 05:35 AM
Check the EvoX section. i believe there is a maintenance sticky that has excerpts from the service manual.
You can use any synthetic 75w-90 LSD gear oil in the rear diff and transfer case.
Old Apr 13, 2011 | 05:42 PM
Slee256's Avatar
You're welcome....
https://www.evolutionm.net/forums/mi...ml#post6750417
Old Apr 14, 2011 | 07:27 PM
xi's Avatar
xi
Thank You!!
ineedboostman
12
Dec 6, 2016 10:30 AM
evobeatsti
For Sale - Cars For Sale
18
May 26, 2009 03:40 PM
CDeutsch
Oct 9, 2008 12:11 PM
Thomar
Jun 24, 2008 07:58 PM
atc1174
39
Dec 26, 2004 04:33 PM
