Daytime Running Lights 'Off'?
How do i permanently turn off the DRL feature?
How do i re-wire so the driving lights can come on with the parking lights?
THX!
THX!
This subject has been covered quite a bit. Search around, the answer depends on if you have the factory HID headlamps or standard halogen.
DRL with factory HID's = pull # 13 fuse (if I recall) or DRL with Halogen = DRL harness (member makes them).
this^, jrox makes the harness
Instructions at http://www.***************/forums/sh...ad.php?t=27770
I assume i do everything except hook up to ballast (for now
) since all i am doing is defeating the DRL with the stock Halogen lights...
to follow up...
jRox kit is very professional - well built.
Instructions were good - install took less than an hour.
Note:
-lift up on the p/s washer bucket (it slides off the bracket) to access the bulb connection.
-remove the air inlet snorkle and box with silver bracket blocking the d/s bulb connection. This reveals the ground connection points.
-if the kit does not have zip-ties - go get some to properly lash the wires.
Note:
mda56
E85 / Ethanol
69
Jul 5, 2017 07:52 PM
jason42003
Jan 20, 2014 12:34 PM
