UR LDP or SDP?
Old Jun 9, 2011 | 05:22 PM
KeDoSH's Avatar
UR LDP or SDP?
which do you prefer, and what exactly is the major difference? in the LDP better in the long run if i wanted to upgrade my turbo?
Old Jun 9, 2011 | 06:33 PM
Krisko's Avatar
LDP is Evo X only. SDP is for both. LDP comes with a better o2 housing, you have to use the stock o2 housing with the SDP. LDP is only good for bigger than stock turbos
Old Jun 9, 2011 | 06:38 PM
robyn402's Avatar
UR has a ldp for ralliarts,
pretty sure CBRD is using it on the ralliart they're building, i've yet to hear any info from anyone using it though... probably a good idea to get if your going with the re-man'd turbo from cbrd and their up comming replacement manifold
Old Jun 9, 2011 | 06:45 PM
KeDoSH's Avatar
yeah, the UR site has a LDP for the RA. so i might as well go with that for now since in the long tun, well not too long. i will be upgrading to a larger turbo.
Old Jun 9, 2011 | 06:48 PM
sstevojr's Avatar
The ralliart LDP cant be used for the Evo X turbo (the o2 housing is different). Additionally, I've heard nothing but bad things about that LDP (at a local performance shop 8 out 10 UR Long DP's cracked, due to the design of their flex point).
Krisko's Avatar
Wow never noticed they had an RA one, my bad. But still, the o2 housing is the only difference. The turbo on the RA is too small to notice a big difference.
Old Jun 9, 2011 | 07:07 PM
03chi-town0Z's Avatar
Very interested to hear some more on this as I was leaning in this direction, along with CBRD's manifold once it is released. PM if you don't want to go waving it about.
Old Jun 9, 2011 | 07:53 PM
KeDoSH's Avatar
so the LDP wont work with either the RA or EVO X TURBO's?
Old Jun 9, 2011 | 08:19 PM
CBRD's Avatar
The UR u2/downpipe is awesome on the RA! Our car is mega even with stock catback!
Old Jun 9, 2011 | 11:14 PM
robyn402's Avatar
the UR ralliart LDP will only work with the ra turbo/manifold, and you heard it from the man himself its awesome lol
Old Jun 10, 2011 | 04:22 AM
KeDoSH's Avatar
so is it worth getting the LDP? its $350LDP compared to $150SDP. does one give more power than the other? and is it worth buying for use of COBB STAGE 2, 93OCT?
Old Jun 10, 2011 | 09:41 AM
robyn402's Avatar
i personally would only get the long DP if your going to be going with the reman'd turbo and replacement manifold from CBRD
if your just sticking with the stock turbo and manifold and just going with bolt on like intake and exhaust i'd save the cash and just get the short DP as thats what the cobb stage 2 would be calibrated for since it was the only DP available when the maps were made awhile ago and cobb has pretty much turned their backs on the RA's so it definitly wouldn't be calibrated for a DP that replaces the 02 housing
i'm personally waiting to hear from cbrd when they finish the manifold and turbo set up before i pull the trigger on a turbo/manifold/DP.
As i'm either going with the RAD or an X setup just waiting to see results from the RAD/replacement manifold before i decide
Old Jun 10, 2011 | 09:51 AM
KeDoSH's Avatar
ok, i think i understand now, haha.
Old Jun 23, 2011 | 12:18 AM
dfoote's Avatar
Good to know, I almost made the same mistake
Old Jun 23, 2011 | 12:24 AM
AntiBlitz's Avatar
Well considering i have the ldp on my car, i have produced great numbers(X swap), and i was tuned by CBRD. I would say without a doubt it helped my car get much more out of it.
