is the emblem only glued on to the trunk?
Old Aug 8, 2011 | 05:53 PM
Chaz17's Avatar
hey guys just had a quick question because i wanted to paint my emblem a different color. is the trunk one simply stuck on there with the glue stuff they use or is there screws/prongs that hold it in as well? same question for the front emblem as well. wantde to see if its easier to remove the emblems and spray them or just tape off and spray. thanks
Old Aug 8, 2011 | 06:15 PM
total0wnage's Avatar
Im pretty sure its just glued on like the front.
Old Aug 8, 2011 | 06:25 PM
Drew314's Avatar
Yes, it is just double sided molding tape. Get out your fishing line and drag it behind it, then use goo gone to remove the residue. Works like a charm. I plastidipped my , so now I am rocking the black diamonds.
Old Aug 8, 2011 | 06:46 PM
AntiBlitz's Avatar
Front glued, back glued, with the exception of the sportback. Has like a screw or something in the back to help hold it on since the curves of the SB are a lil dramatic back there. Remember once you take it off the glue may not stick right back on. Might need to buy some glue. Also use the search function, way too many silly topics like this, that have been covered about a thousand times
Old Aug 8, 2011 | 09:00 PM
Chaz17's Avatar
sorry about that. anyone know exactly what i should use to glue it back on and where i could find the stuff? thanks.
Old Aug 8, 2011 | 09:14 PM
aaronk's Avatar
double sided thin 3m tape
Old Aug 8, 2011 | 10:45 PM
Chaz17's Avatar
gracias.
Old Aug 9, 2011 | 10:47 AM
neogeo64's Avatar
what about the sports backs? the rear emblem is curved on the hump of the hatch. is this just glued on as well? I'm thinking I may want to remove a few off the back.
Old Aug 9, 2011 | 11:00 AM
iainash's Avatar
Old Aug 9, 2011 | 02:11 PM
SudzRA's Avatar
Make sure if you're going to put it back on to use 3M tape as mentioned above. Other, cheaper, mounting tape will leave a ridiculous residue on your paint if you ever remove it again.
Old Aug 9, 2011 | 03:06 PM
neogeo64's Avatar
Originally Posted by iainash
i feel like such a newb..
Old Aug 9, 2011 | 03:58 PM
AntiBlitz's Avatar
yep afaik, sportbacks, cannot remove their respective mitsu rear badge, as you will then have a hole in your hatch. Unless you patch it or cover it. That then is up to you!
Also there is a 3m emblem glue if i remember correctly. Its kinda like superglue for emblems, you can also do the 3m thin tape.
XFTW
Jul 14, 2012 05:30 AM
Boostme
Aug 24, 2011 12:42 PM
PICASO83
Aug 9, 2011 05:51 PM
vivac2
Evo X How Tos / Installations
20
Feb 23, 2011 04:26 PM
