Down shifting
Old Oct 10, 2011 | 11:03 AM
bryan9915's Avatar
Down shifting
Does anyone manually downshift the car as a means of slowing down? Coming from a 6sp manual I would down shift all the time. But I am not to knowledgeable of the twin clutch trany. Dose down shifting for slowing down cause any damage? Also, I noticed when I do it the instant MPG reading shoots all over the place (prob trying to match the enging speed to the wheel speed) and then some times still has a decent mpg reading. Is that accurate? I know a lot of newer cars the ecu will cut / significant reduce the fuel when coasting at higher rps and use the cars momentum to run the accessories on the belt. Doing so obviously to save on gas.
Down shifting is not a big deal I am just more curious than anything.
Old Oct 10, 2011 | 11:22 AM
nunyas's Avatar
I down shift to 2nd gear almost every time. After getting to 2nd, i let the car handle it mainly because 2nd is short enough that it can accelerate from 1200 rpm without any trouble
Old Oct 10, 2011 | 12:23 PM
MTZL's Avatar
I downshift all the time every time.
I dont like 1st gear so I stay out of it as much as I can.
I downshift so I dont have to use brake.
39+K miles & counting... Brakes are still good.
Old Oct 10, 2011 | 12:54 PM
TOralliart's Avatar
I would recommend letting it downshift on its own. Brake pads are significantly cheaper to replace than tranny and engine. Just my opinion.
Old Oct 10, 2011 | 01:03 PM
total0wnage's Avatar
i dont downshift much to engine brake and if i do the rpms are never over 3k i just downshift when im coming to a light to 5th and let the car do the rest cause its enough to get me to stop smoothly
Old Oct 10, 2011 | 02:10 PM
BillCosbysPudding's Avatar
I do it all the time, the highest I usually let it go is 4K.
Old Oct 10, 2011 | 06:37 PM
kyoo's Avatar
saves gas!
Old Oct 11, 2011 | 07:01 AM
Cesarn2928's Avatar
same... down shift to 2nd.. then i let the car handle from 2nd to 1st.. lol
Old Oct 12, 2011 | 09:00 AM
dubkeith's Avatar
Word. Sport mode does a pretty good job of keeping the engine braking on the up.
Old Oct 13, 2011 | 09:49 AM
bryan9915's Avatar
Thanks for the input. Any thoughts on the effect on mpg's?
Old Oct 13, 2011 | 10:33 AM
RazorLab's Avatar
While engine braking, it's basically a big air pump and the injectors are shut off.
Old Oct 13, 2011 | 10:36 AM
Pantah's Avatar
The RA has so little engine brake, close to zero compared to other cars I drive. Is that be course of the turbo or what ??
Old Oct 13, 2011 | 10:41 AM
RazorLab's Avatar
Below a certain MPH or braking the clutch packs open up, unlike a manual trans car unless you put the clutch in.
If you just let off throttle and let the car decel it engine brakes just like any other car.
Old Oct 14, 2011 | 10:32 AM
bryan9915's Avatar
That's what I was wondering. So if the injectors are off then it is no using fuel in the process. So I'm not waiting gas.
