Gauges vs Evoscan
Old Feb 17, 2012 | 07:51 AM
angryplatypus75's Avatar
The only thing I don't like about the Evoscan GPS is that it seems to lend itself to a wiring mess. Between the power adapter, the USB hub, the Tactrix cable, the wideband cable, all the adapters to connect the wideband to the hub, all running to a GPS unit hanging off the windshield. Just seems like it would get messy quickly.
I guess for now I will probably plan on setting up at least boost and AFR gauges, and once Evoscan for Android is a thing I'll look into doing something similar to Exyia's setup, using a cheaper Android tablet.
Old Aug 20, 2012 | 07:44 AM
Mforbes's Avatar
Originally Posted by Exyia
you will still need a wideband gauge/source. evoscan can't read it from the ECU/Tactrix sadly
the fact that you'll need to get a wideband anyway, boost gauges so cheap, and much easier install, most people just get a boost/AFR gauge and call it a day
but just to tease - I use both
hi sir, Where di you get your bezel from? Also, what size tablet is that you have in there. I Have the 10'' windpad, Can you recommend me to somewhere that I can get the bezel like you have to mount my tablet in my dash?
Mitsu.kid.02
Lancer Engine Management / Tuning Forums
217
May 25, 2016 10:47 AM
papabeardoe
Mar 14, 2016 04:47 PM
RngrYogi
Oct 17, 2015 11:41 PM
jrsimon27
Jun 4, 2009 09:13 PM
saiyuke
Jul 6, 2008 01:13 AM
