Fat RA
Old Apr 22, 2012 | 12:58 PM
Steven_Trujillo's Avatar
Fat RA
So I had to get my RA weighted today so I could move back home (just got out of the marines) and I must say wow 3400 lbs! It need to lose some weight lol. Oh and that was with out the spair the the trunk.
Old Apr 22, 2012 | 01:31 PM
pbassist12's Avatar
mine weighed 3460 with everything and 3600 with me in it
Old Apr 22, 2012 | 02:12 PM
sstevojr's Avatar
3400 that's it? My SB is ~3800 with a full tank and me in it. Did you drain all fluids to make 3400, cuz that's the same weight as a IX?
Old Apr 22, 2012 | 02:15 PM
Brownie614's Avatar
mine with me in it 3460 and my system
Old Apr 22, 2012 | 02:44 PM
sstevojr's Avatar
What, no way. The curb weight is 3500, what all did you strip from the car to loose 100lbs PLUS your own weight AND your stereo.
Old Apr 22, 2012 | 04:51 PM
Jechttt's Avatar
3360 with borla exhaust muffler, no floor mats, glove box removed.
Also have motegi 17" and winter tires on.
I am moving friday, and will be reimbursed for total weight moved
Old Apr 23, 2012 | 06:08 AM
gaabbee's Avatar
On my title it says 3800 lbs which I don't believe
Old Apr 23, 2012 | 08:18 AM
Well I have the AMS CBE so I'm thinking that cut a lot of weight from it and it had all the fluid topped off.
Old Apr 23, 2012 | 10:38 AM
Brownie614's Avatar
no when i went to the dump to go trash my tbe n all the other stuff when i came out it said that i got the paper somewhere but now im sure its alot more bec i have a custom sub box with 2 new memphis audio subs n a bigger amp
Old Apr 24, 2012 | 01:25 AM
AlphaKennyBody's Avatar
When my car weighed in... I know it was either 3260 or 3360.... One of the 2 for sure... I gotta look for my Dsport Mag. That full weight with Spare.
Old Apr 24, 2012 | 09:26 AM
sstevojr's Avatar
So your saying your Ralliart weighs less than your Evo IX
Old Apr 25, 2012 | 08:49 AM
aaronk's Avatar
Somethings wrong here, no way your RA weighs less than a IX
Old May 3, 2012 | 05:31 PM
dubkeith's Avatar
100% stock with close to a full tank and me was 3650 at a weigh station. I doubt its that accurate, but i can't see the RA being much heavier. My buddies A3 2.0T Quattro weighed 3700lbs.
Old May 3, 2012 | 09:53 PM
My IX weights much less as it turned into a Drag car instead of a Time Attack Car...
Trust me we were all shocked to see the weight also. DSport Tested along with RobiSpec seeing the tech sheet. =)
Unless the scales used aren't correct then so be it. The Evo X that weighted in that day from Robi was in the 3500's?
I'm almost positive it's one of the 2 numbers listed above 32 or 3360 I can't find my magazine or my last tech sheet..... But i know for a fact when the testing was done they said for sure you can obviously tell my car was lighter lol. Maybe 2011 is different? I did change out parts liek the crash beam, exhaust..... I think I did take out the spare tire, tools, and extra crap like the jack and what not.
Old May 3, 2012 | 10:09 PM
There are also many privately reviews of the Ralliart weighing in at 33-34xx LBS.
Here's a friend of mine.
Originally Posted by 2muchboost
When I did my corner weight/Alignment my RA was 3299 lbs with about half a tank of gas and with the spare tire still in the trunk.
So yes my numbers stand correct.... My numbers were on a Corner Balance Scale also
