Just ordered new engine!!
Old May 30, 2012 | 08:28 PM
Jdunn502's Avatar
Originally Posted by NFSLancerRA
With the amount of stuff that they already know, Spec-Ops will sort you out. If you want to pull the trigger on the Garrett 3076R, Let me know. Matt and I need to talk at some point.
pmed
Old May 31, 2012 | 10:33 AM
RazorLab's Avatar
Originally Posted by Jdunn502
It is very good advise but before the motor blew i wanted more power. I want to make at least 350awhp.
You don't need a built motor for that.
My RA is 400whp+, stock motor, stock SST. 21k miles, 2 years old.
Proper tune and parts is all you need.
Old May 31, 2012 | 10:54 AM
03chi-town0Z's Avatar
Keep in mind, stock X turbo is capable of low 12 second passes (which is what you mentioned you were after) in a well-sorted car. Ported stock X turbo on e85 can run 11's
Old May 31, 2012 | 11:30 AM
NFSLancerRA's Avatar
Yeah, but go big or go home.
Old May 31, 2012 | 11:42 AM
boozeup&riot's Avatar
If the turbo isn't the weak link (the tranny seems to be), how does going with a bigger turbo help him? Wouldn't it shift his whole powerband to the right also, making the car less fun to drive at the same power levels? I really don't think he needs the bigger turbo to reach his goals.
Old May 31, 2012 | 12:40 PM
nunyas's Avatar
The transmission isn't that weak. There are plenty of people out there that are putting more power through the SST than this guy wants to make. Bryan (razorlab), the GST basemap creator, for example, just stated that he's putting 400awhp to the ground without problems with the stock long block and stock transmission.
Old May 31, 2012 | 12:55 PM
He also doesn't list what turbo he is using. It's my understanding that you don't really want to push the tcsst much past 350tq, is that correct?
I recognize that going faster, or "going big or going home" is exciting. I'm also aware that he can probably extract more power out of the car with a bigger turbo, and run a tune that keeps his tq numbers nice and safe while still making more power. However, he is still shifting that powerband more and more to the right. If you make 50 more awhp, but you have to spool up 500rpm later to do it, there are obviously tradeoffs involved that may not necessarily translate to a more fun car to drive. Just an observation, take it for what its worth. There's also no guarantee that it'll make him all that much faster in the 1/4, though he'll likely trap at a higher speed.
There's also nothing wrong with saving some money and seeing what the guys at spec-ops are able to do with the car as it is with the new motor and new tune in it.
Old May 31, 2012 | 02:06 PM
Also, fwiw, I'm going off this thread:
https://www.evolutionm.net/forums/09...sst-loves.html
I realize the guys at spec-ops may know what they are doing. Same with Razorlab. AMS blew out the clutches on their vehicle running 300tq in about 5-6 months. This was on an fp red making about 350whp. Given the experiences are mixed, it sounds to me like a "luck of the draw" sort of deal. That thread is an interesting read. Have there been any more breakthroughs with the tuning for tcsst (tcu)?
Old May 31, 2012 | 03:01 PM
CBRD's Avatar
Bryan (aka razorlab) is running our BBX lite and FMIC-
cb
Old May 31, 2012 | 03:17 PM
Thanks for the clarification cbrd. My input probably isn't helpful. I'll just bow out.
Old May 31, 2012 | 04:01 PM
RazorLab's Avatar
You can see all the details about my RA here:
https://www.evolutionm.net/forums/09...sportback.html
Old May 31, 2012 | 04:43 PM
The RA and Evolution X are totally different animals than the Evolution IX, FWIW.
Old May 31, 2012 | 04:49 PM
RalliMark's Avatar
Are these numbers still correct 370whp/326 wtq? In the post it states your at 400whp.
Old May 31, 2012 | 05:29 PM
sstevojr's Avatar
That was....3 year ago
1 or 2 things may have changed since then
Old May 31, 2012 | 05:33 PM
sstevojr's Avatar
No, those number were on stock RA CBE (stupidly small). When he upgraded to a full 3" the fuel system maxed out at 400 (more to be had when new injectors are acquired). Let alone that dyno is insanely.....stingy with numbers.
