Newbie here
Newbie here
Okay so I have a 2012 ww ralliart and I want to make it faster. What are the five first steps I should take on doing so. Brands, price, options. Anything will help I'm clueless but I want to join the ralliart community. Thanks guys
First 5 things you should do:
1. Read the stickies before starting redundant threads like this
2. Read the stickies before starting redundant threads like this
3. Read the stickies before starting redundant threads like this
4. Read the stickies before starting redundant threads like this
5. Read the stickies before starting redundant threads like this
Any questions?
Any questions?
Any questions?
Any questions?
On a more helpful note, advice on what you should do first really depends on what your end goal is and what your budget is. You want 800 WHP? Well things you should do for that effeciently will differ from say if you what 300 WHP.
No FMIC? Seriously, that should be done before turbo swap or at the same time. Ours is WAY to small for upgraded turbos. Also if your looking at stock X turbo and no more, the RAD is an option as well. Less money...will net you about the same. The 3 port is up in the air if it actually does anything for our cars and there is some that argue that it is WORSE. And before you think of aftermarket turbos or the X turbo, switch out the plastic BoV for crying out loud. Also it should be noted that the RAD turbo costs about as much as an exhaust system and will net you WAY more power then an exhaust. Course if you can't put the RAD in yourself, your looking at more labor costs...but for those on a budget the RAD is better money spent then then an exhaust if your looking for speed.
