How do I use my Ipod with this fancy stereo?
Old Sep 20, 2013 | 10:38 PM
jangempo's Avatar
I just got a 2010 ralliart with the premium package. The problem is that I can't seem to plug my ipod into it to listen to my music. The only jack I see is when I hit the open button, but I can't operate the stereo when it's swung open. How do I play music from my Ipod thru the rockford fosgate stereo.
Old Sep 21, 2013 | 05:19 AM
NolaArt's Avatar
There should be a USB plug in the glove box in the upper left hand corner. Just plug your ipod cable into that and then you can control the ipod thru the radio controls.
Old Sep 21, 2013 | 08:39 AM
jangempo's Avatar
Doesn't seem to be anything in the glove box. There is an old style a/v connection, with the red white and yellow near the ashtray. Could I use a wire with the red and white prongs on one end and a regular 3.5mm audio prong on the other in AUX mode?
Old Sep 21, 2013 | 01:16 PM
Firebuck2059's Avatar
You are correct, in a 2010 you have to use the red/white cables and select aux. on the stereo. There is no usb connection for the 2010.
Old Sep 21, 2013 | 01:54 PM
jangempo's Avatar
okay, thanks. My girlfriend was upset that she couldn't listen to her stuff on the new system.
Old Sep 21, 2013 | 05:04 PM
I have tried a couple of those fm transmitters for the ipod but honestly I was disappointed with them. I ended up getting short cables and leaving them plugged in the rca inputs. The main disadvantage is that the ipod will not charge but that may not be too bad.
Old Sep 22, 2013 | 09:29 AM
mattnshell's Avatar
Us the AV connection. Goto locks Wal mart or best buy get AV to Aux cable. Got one at Wal mart for about 8.00
Old Sep 27, 2013 | 03:29 PM
mjev8's Avatar
do you have bluetooth?
Old Sep 28, 2013 | 07:42 AM
jangempo's Avatar
I got the av cable. It works well after widening the prongs as the holes seem to be a bit big. I can't get blutooth to work. When I try to use blutooth, or access the blutooth system via the console It says there's a system error.
Old Sep 28, 2013 | 10:40 AM
crak's Avatar
how do u set up bluetooth to play via the standard stereo?
Old Sep 28, 2013 | 12:20 PM
mattnshell's Avatar
As far as I have read and dug into this matter I can't find anywhere that says you can Bluetooth stream music.
EMonz57
Outlander Sport
Apr 4, 2013 12:33 PM
David Buschur
12
Aug 27, 2010 11:20 AM
Fast_Freddie
11
Jun 16, 2007 01:29 AM
JYabbz
11
May 24, 2007 10:55 AM
sinaloa86
12
Mar 23, 2006 03:25 PM
