new 2010 RA owner
new 2010 RA owner
I got my ralliart about 3 months ago and yea it was fun to drive but now I'm looking for more power nthn too major but i want to feel the difference I've seen a lot of threads about the evo x turbo swap and i think i might go that direction , but i need a more detailed parts list , and which aftermarket brake kits should i get ?
the reason why I'm getting an aftermarket brake kit is becoz I'm living in an unrecognized country atm and i cant get the stock brakes and even if i do they will be more expensive than lets say a stoptech kit
Evo X turbo swap how to and parts needed are in the Ralliart Turbo thread and a believe its stickied. You can also go the CBRD Rad lite way which is the Ralliart turbo upgraded. Both require a tune as does an intake. I suggest starting with intercooler, intercooler piping, exhaust, high flow cat or testpipe, intake, boost control solenoid, and a tune.
im liking those numbers i would probably go for this ( around how much would all of this cost ) ? and would a full evo X swap work ? just out of curiously coz i can get my hands on a cheap full evo engine and transmission
No need to swap the motor. You can easily do the Evo X or Rad Lite turbo on the Ralliart. Trans swap is possible but not necessary as there is a way to get the S-Sport and launch control like the Evo has through a tune (which I also have).
Rad Lite turbo - $900
Intercoolers - $400-700
Piping - $200-400
Exhaust - $500-900
Tunes - Right around $500-600
Boost Control Solenoid - $100
Intakes - $150-300
These are all estimates depending on what company you go with. I bought basically all my parts from Lancershop.com and my tuning was done by Boostin Performance
Piping - $200-400
Exhaust - $500-900
Intakes - $150-300
Before you go parts shopping, I highly recommend you buy a tactrix openport, download ECUflash and flash the GST Basemap tune on your car. More info:
https://www.evolutionm.net/forums/09...t-basemap.html
Simply flashing the ECU brings quite a significant increase in power from the car.
It's also useful later on, when you've upgraded/replace all of those bolt on parts, and you engage the services of an e-tuner (as I can't imagine many engine tuners based in Cyprus would have specialised knowledge of the SST that's required to properly tune these cars - in fact in the number of tuners with SST knowhow in the world you can count with the fingers of two hands).
AMEN to that
If you are recirculating it back to the intake then yes I would use it. If you want to use it and vent the air to atmosphere than hell no. Our cars do not like venting the air to atmosphere setup. Yes there are some people that use them but you need a very finely dialed in tune to do so. If you want to get rid of your stock one then get an all metal evo10 oem one. They run amazingly and will not leak like the plastic one. Unless you have a monster turbo with tons of boost then you do not need a fancy aftermarket bov or dv.
This one works amazing and is a dv or recirc valve setup. If you want to upgrade this is a great investment. Had this for a couple years now and works amazing
http://www.lancershop.com/customer/p...cat=240&page=1
Also the greddy you are asking about requires flange adapters and a special pipe to make it work correctly as per their website. It is not as simple as plug and play. You need additional hardware to make that bov work. With how new you are to this I would consider my advice. I would do what many of us ralliart guys are doing and use the oem one that I mentioned in my previous post. Take this for what it is worth but with so many of us using the OEM evo x valve that should tell you something.
DirtyRalli
25
Sep 26, 2016 06:17 PM
rhouse24
May 23, 2014 08:35 AM
