AC rubber hose replacement help
Old May 27, 2014 | 11:46 AM
Snipingdude's Avatar
Hey guys, Has anyone replaced their AC line? I mean the rubber portion of it? I called the dealership and they want $800 for the job!! Is there anyway to do this myself and how to remove the hose? Thanks for any help...
Attached Thumbnails AC rubber hose replacement help-0527141434a.jpg   AC rubber hose replacement help-0527141434.jpg
Old May 27, 2014 | 04:53 PM
Murdered Out's Avatar
Is that hose actually rubbing?
Old May 27, 2014 | 07:10 PM
Athrun88's Avatar
Why are they charging you if it's clearly a design flaw? That makes no sense to me.
Old May 27, 2014 | 07:39 PM
02-Lancer-Es's Avatar
Call your local Ac shops , most of them repair ac lines/hoses for about $40 !
Old May 28, 2014 | 06:27 AM
Veronica's Avatar
1. Is the hose leaking? If not, I would band it (put metal sleeve over it and clamp it).
2. That is a large gap for the belt to move to the hose - are your engine mounts bad - moving the engine too far?
3. I would just buy a salvage yard hose and have any garage evacuate, oil charge, and charge the a/c system...
Old May 29, 2014 | 06:32 AM
Thanks guys
Yeah its leaking terribly so I need to replace it. The belt ate into it and all the 134 leaked out. I actually bent the hose back away from the belt. It must have moved when I hit a deer. I figured out I can buy the hose replacement online with both metal ferrules attached for only about $15. Only thing I would need to do is crimp and evacuate the system. Dealership wanted $800!! Thanks guys
c08
Oct 1, 2016 05:07 PM
timmycat
Aug 30, 2016 12:58 PM
mike594x
Dec 11, 2015 06:29 AM
pitchblende
Sep 27, 2015 01:33 PM
cmz
17
Jun 16, 2014 07:22 AM
