Spark Plug Questions
Old Jun 8, 2015 | 01:59 PM
melonfarmer's Avatar
Hey guys, I have a quick 2 questions regarding spark plugs.
1) It seems like everyone on here uses the OEM NGK ones but those are pretty expensive where I live (40 bucks each). An alternative that Napa has are Champion Iridium OE-Type plugs (12 bucks each). Does anybody have any expirience with non NGK plugs? Has anything gone wrong for you guys?
2) The default gap on these plugs is 0.044. Is this acceptable, or will I have to gap them since most people here are in the 0.02 region?
Thanks for your replies!
Old Jun 8, 2015 | 02:33 PM
Raikiri's Avatar
40 Each? Thats the typical price for all 4 around here I think. Search the vendors and see what price they can give you.
Old Jun 8, 2015 | 03:40 PM
Murdered Out's Avatar
0.024 - 0.028 Factory Spec
Old Jun 9, 2015 | 10:04 AM
kornkid42's Avatar
1. Can you use Amazon.com?
2. No, they will not work, and if you try to gap them, you will most likely damage the tip.
Old Jun 9, 2015 | 12:36 PM
Raikiri's Avatar
What he said. The proper plugs should already be pregapped already to what the car needs.
Old Jun 13, 2015 | 07:05 AM
JoshB's Avatar
I'd stay with stock, to me the money you save isn't worth something going wrong.
Im evo swapped and I actually blew the tips off 2 of the sparkplugs (60k miles on them) doing quarter mile runs. Being that close to having catastrophic failures I'd never risk running a lower quality then spec parts. Sure you save 50$ but you sure would be kicking yourself if it doesn't hold up.
Magrud3r
Sep 25, 2014 06:22 PM
AWDBus
Dec 8, 2011 11:01 PM
Guerillah
10
Sep 24, 2011 08:27 AM
fimotorsports
Nov 19, 2007 01:55 AM
QAT-R
Aug 31, 2006 11:05 PM
