Power output question
Old Apr 10, 2016 | 07:25 AM
b1u3's Avatar
Looking at a Ralliart that has a short ram, turboxs turbo back, boost controller and tune. Realistically, what sort of power/torque to the wheels can I expect?
Old Apr 10, 2016 | 01:15 PM
DWILSON357's Avatar
Depends if its tuned, a cobb ots tune, or not at all?
Its eorth noting that ebcs csn be setup to run like the stock unit by omitting an output...forget which.
From whats there though I would geuss you around 210 whp...others can give a more accurate number...check cobbs website they have general numbers for that setup
Old Apr 10, 2016 | 02:38 PM
b1u3's Avatar
He said it was dyno tuned. I'm just wanting something that is close to my MS3 in power output.
Old Apr 11, 2016 | 12:46 PM
blkdrgn09's Avatar
I have a 2010 RA dyno tuned with following mods and I'm at 250whp/292wtq
*high flow cat
*muffler delete
*k&n high flow filter
*boost pill (3-port boost controller will probably bump you up a bit more)
*evo x intercooler and intercooler piping
*evo x bpv
Old Apr 11, 2016 | 05:22 PM
Slee256's Avatar
*high flow cat
*muffler delete
*evo x bpv
Basically the same mods and numbers for me as well, which you can see below in my "signature" line.
Old Apr 11, 2016 | 07:27 PM
blkdrgn09's Avatar
Yep! Didn't have s-sport then and trans was slipping a bit cuz old fluid. Now new fluid, s-sport, and borla cat back as well. So picks up a bit better even!
#1deliveryboy
Oct 19, 2006 09:56 AM
damianhindley
12
Mar 12, 2006 04:24 PM
TrinaBabe
10
Nov 16, 2005 10:01 PM
chapter8
Oct 6, 2004 09:02 PM
