Ssp deap pan
Old Nov 29, 2016 | 08:54 PM
Omar S Abbood's Avatar
Question Ssp deap pan
Hi , i am trying to get ssp deap oil pan for my sst tranny , is this something i can do it on my own or need a professional installation from your experience
Old Nov 30, 2016 | 05:01 AM
DWILSON357's Avatar
I think this is one of those "If you have to ask then it's probably too much to handle". the job itself isn't difficult but it will require doing a flush of the SST(since you are removing the thing that holds all the SST fluid) and you might as well replace the filter as well.
Old Nov 30, 2016 | 12:29 PM
silthos's Avatar
Deep pan is unnecessary for the sst. Sump kit is a better investment for the car.
Old Nov 30, 2016 | 02:09 PM
hi thank you for your reply I was already thinking about changing the transmission oil and filter so its going to be drained anyway so you know like I was thinking of doing that but I just wanted to know if it's going to be hard like in an area that's it's so tight or narrow so I cannot just get it done, or i had to take the transmission out to do this , i have no clue on this
Old Nov 30, 2016 | 02:11 PM
I was thinking because it has dip stick and cool down the oil faster as i live in Az its 120 degree in summer, also what is this kit and what it does ?
Old Nov 30, 2016 | 03:55 PM
silthos's Avatar
Utilizing the same method that most auto manufacturers use to control transmission temperature, the kit uses the engines coolant to maintain the transmission in its best operating temperature range. When the transmission is cold, it speeds warm up. When the transmission is hot, the engine coolant cools the transmission. A built in thermostat protect the transmission should the engine over heat. This results in a very stable transmission temperature, which is critical for best operation of the transmission.
Designed to heat SST transmission fluid quickly to operating temperature and keep it there.
Billet construction with embossed DMS logo. CNC for exact fitment. Increased rigidity, coupled with increased volume. Temp gauge fitting port - 1/8" NPT.
Built in thermostat protects the transmission should the engine over heat.
Kit comes with all AN fittings, high temp nomex braided hoses for convenience and ease of installation.
Old Nov 30, 2016 | 03:58 PM
silthos's Avatar
This is for the dodson heated sump kit. Just save your money and get this. This will be the only thing you need to keep the trans temp in check.
Old Dec 1, 2016 | 03:00 PM
Any idea if this will have a dip stick so you know when to stop and not over fill the transmission
Old Dec 1, 2016 | 03:57 PM
DWILSON357's Avatar
Don't worry about the dip stick. Most guys make sure they get about 8l out of the transformer then put 8 back in.
Roen
Mitsubishi TC-SST Discussion
Mar 19, 2014 08:29 PM
AWD Motorsports
May 26, 2010 09:01 PM
tjac357
10
May 17, 2010 09:30 PM
tjac357
13
May 17, 2010 10:55 AM
philamthebest
May 12, 2010 06:32 AM
