Ralliart Sportback Tow Hook Question
Old Feb 10, 2017, 08:39 PM
c08
c08's Avatar
So I've been looking for (functional) tow hook options, and so far all I've found is:
1. Rear tow hooks that work with single exit exhaust (which I don't have)
2. Front and rear options that work with JDM Evo X crash beams (which I also don't have), or by modifying current crash beams
Are there any other options? Has anyone tried to fit the Beatrush Evo X rear tow hook to a Ralliart before? It replaces the OEM tie down hook, which appears to be identical between the Evo and Ralliart. On the Evo the hook fits between the exhaust tip and the OEM rear diffuser, so I'm not sure if would fit the same with the Ralliart.
I just wanted to check and see if there are any other options before I decide whether to order any more expensive parts.
Old Apr 14, 2017, 11:21 AM
neogeo64's Avatar
you can buy ralliart EUR/JDM crash bars (under $100) instead of Evo X EUR/JDM crash beam (over $250).
It's a little cheaper but still uses the thread pattern of the evo tow hooks.
I ended up modifying mine with the redline tow hook kit front and rear.
http://www.ebay.com/itm/191890377493
Old Apr 16, 2017, 08:07 AM
c08
c08's Avatar
Thanks, so is the Ralliart EUR/JDM crash bar just the equivalent Ralliart part for the Evo X crash beam then? I picked up a Beatrush Evo X tow hook for the rear but haven't had a chance to try to install it yet to see if it fits. Whenever I take my front bumper off to install a new intercooler down the road I'll probably try to replace the bar/beam in the front though so I can have a tow hook for that end as well.
evazerone
Dec 24, 2017 03:01 PM
jRox
23
Feb 25, 2017 02:28 PM
GIjoe27
Mar 24, 2014 06:48 PM
pips
Dec 21, 2011 03:23 PM
evil03
Apr 13, 2009 11:11 PM
Quick Reply: Ralliart Sportback Tow Hook Question
