Need Help Please !!-
Having problems with alternator charging battery ,
i replaced fusible link and altenator and still not charging battery . i checked the wire going from the battery to the altenator and it has jucie so idk what to do now got a ticket thish morning cuz i cant move the car battery dead from not charging
Jump start the car so you can move it and then while its running check the alternator output with a voltmeter. It should be reading between 14 to 14.4 volts. If not then your alternator is bad and needs replacing.
Take the battery out to your local AutoPart and let them check it out.
Batteries are mostly the ones that go out.
If you already did it. Then take the Alternator out and take it to the autopart. They have machines that check it out.
Both tests are free in most auto part stores.
nlp187
Jul 8, 2012 10:32 PM
imdrew12
30
May 20, 2010 05:30 PM
