Ralliart stuck in P.
Old Aug 24, 2021 | 03:54 PM
Panda-Ralliart's Avatar
Ralliart - gear stuck in Park
Hello, earlier I was driving to Target and after I got out and hoping to drive home, I couldn’t get my ralliart to shift from P to D. This had happened a few times but today took much longer to shift. I stop, restart car few times. Step on brake really hard and then it finally work. Can someone please advise if this is a major concern or easy fix please?
thank you.
year is 12 Ralliart.
Old Aug 29, 2021 | 04:40 AM
bn880's Avatar
First thing I would advise is to pull codes. (you can post them here)
2nd do a re-teach on the SST transmission.
If the oil has not been changed for a while in the SST, also get that changed with the outboard filter. (re-teach after)
Old Aug 30, 2021 | 07:42 AM
Sorry but what exactly is “re-teach” mean?
Old Aug 30, 2021 | 07:50 AM
bn880's Avatar
You can google that and look it up in this forum, mentioned all over the place and in TSB's as well. Requires a MUTIII (expensive Mitsu tool) or Tactrix cable (cheap aftermarket) and some files/configuration.
egk-69
Apr 13, 2010 08:55 PM
Evoposer
13
Apr 30, 2002 03:00 AM
