EVOX Brembo's on a 09' Ralliart
#76
You could buy Brembo radial mount calipers, but then you would be better off buying their GT kit. If you are willing to use Wilwood calipers, that has been done.
#77
It doesn't matter. The mounting points are way too long. This has been done to death. There is someone in the Evolution X Brakes, Suspension, Wheels, Tires section who is trying this, now. It is a waste of time.
#84
I am really keen to produce the Z06 upgrade. I know that it can be done. I will more than likely need an RA to refit the rear portion of the upgrade. I will be double-checking EVERYTHING this time.
The smaller upgrade is almost ready to go out, again. I have brackets ready to go. I just need to have new spacers made and more bolts ordered. Fastenal is running a bit short on those, ATM. I would hate to have to order them from Chevrolet, as they are $5 per bolt from them (at minimum). But, slowly but surely progress is being made.
#85
#87
