EVOX Brembo's on a 09' Ralliart
Old Mar 12, 2012, 11:38 AM
  #121
masafina's Avatar
this week is supposed to already have made ​​a complete bracket
Old Mar 12, 2012, 12:13 PM
  #122
sstevojr's Avatar
What are you using for the bracket, that looks kinda thin?
Old Mar 12, 2012, 01:39 PM
  #123
nunyas's Avatar
i believe that's actually a template he's making in the pics for his fabricator to use to make the actual brackets
Old Mar 12, 2012, 04:02 PM
  #124
masafina's Avatar
Old Mar 12, 2012, 05:45 PM
  #125
Slyy's Avatar
looking really good man! mass produce this and sell it to us!
Old Mar 12, 2012, 06:03 PM
  #126
Carvs's Avatar
Just a little update on my brackets I have designed. I am running into the exact same problem with the fitment. The offset of the OEM mounts and the inner radius of the caliper interfere with one another. Unfortunately I haven't come up with a solution to this as of yet.
One thing I will say is that I REFUSE to cut my caliper... In my eyes this is a massive loss to the structural integrity of the caliper itself, and I can't see it being safe. It was designed that way for a reason, and it should remain that way.
I am not trying to start a fight, or cause any uprising of any sort, I'm just inputting my 2 cents here... I will continue my work on the drawing board, but I have no promises other than I will try to continue to find a solution that doesn't tamper with the OEM design of the caliper, I feel like this is the responsible thing to do, I wouldn't want to put anyone in danger. I'm not saying that these calipers are going to break, I'm just saying I wouldn't remove material out of such a critical component of the car, and for your safety.
Nevertheless, I am happy someone has found a solution to fitting these onto the car, as well as designing a bracket that works. I will keep everyone posted with what I find in my own studies.
Sean
Old Apr 4, 2012, 05:18 AM
  #127
masafina's Avatar
Some fitment testing for the final product
Attached Thumbnails EVOX Brembo's on a 09' Ralliart-img_0999.jpg   EVOX Brembo's on a 09' Ralliart-img_1001.jpg   EVOX Brembo's on a 09' Ralliart-img_1002.jpg   EVOX Brembo's on a 09' Ralliart-img_1003.jpg
Old Apr 4, 2012, 07:39 AM
  #128
Slyy's Avatar
nice! Looks real good
Old Jun 13, 2012, 05:26 AM
  #129
masafina's Avatar
well is finally done
Old Jun 13, 2012, 07:00 AM
  #130
TrailBrake's Avatar
+1
I am interested in this as well
  #131
Slyy's Avatar
Great job! looks good! sell me and Trailbrake the brackets!
Old Nov 21, 2014, 07:15 AM
  #132
Ralliart09er's Avatar
I am interested in some brackets!
Old Jan 10, 2015, 12:26 PM
  #133
CFMP RAblue's Avatar
Perhaps you should check here first
https://www.evolutionm.net/forums/09...-list-bbk.html
Old Jan 10, 2015, 05:52 PM
  #134
cmb70's Avatar
Originally Posted by chindian
Yeah, it took a while, at first we tried to use the LCA, knuckles, struts, and tie rods off a EVO X, but we ran into wheel speed issues turning on ASC, ABS lights. We have since fabricated brackets using just the caliper and rotor. The car stops on a dime on initiall testing. The car is at race city for some lapping this weekend. Once testing is done we may offer the brackets, calipers, and rotors for sale.,,,, on the Cheap!!
Why would using the spindles and other parts set off codes? Would it be because the ABS sensor is different and the tone ring is perhaps bigger? Would there not be a way to alter these parts or figure out a way to use the stock RA tone ring and abs sensor? I am just curious, since the control arms, axles, spindles etc. are only mechanical parts. I could see maybe the bearings in the spindle/hub being a different size causing some issues but I think with some R&D, this could be doable in the future without a bracket. The install looks sweet though.
Old Oct 31, 2018, 10:06 PM
  #135
sadGuy :'D's Avatar
Hi, I'm quite new in this thing. I don't quite get what you mean by LCA. What exactly do I need? I bought the rotors and calipers but my mechanic says it will be cheaper to sell them and get a big brake kit instead. All I know for now is that I need knuckles. How much does it cost you to install it? My mechanic even planned to remove ABS. Thanks
Quick Reply: EVOX Brembo's on a 09' Ralliart
