I did an alignment on my car the other day, but didn't have any specs. I ended up zeroing out the front toe -steering wheel was off, only had half an hour to do a quickie-. Stock front camber was about -.80*. That seems to be normal from the factory? My stock tires after 2 years had bad wear from said negative camber.
I tried to do a search but my google-fu is weak. I haven't done any suspension mods or anything. So stock settings if anyone is the google master, or happens to have them on hand would be greatly appreciated.
damn j, i woulda left that rear toe alone. toe is the #1 killer of tires. i'm running 0 all around with -2* camber in front and -1.5* camber in the rear and my tires still wear better than the stock alignmnent that causes all that inner wear crap
