front sway bar
Old Feb 20, 2011 | 01:49 PM
canadaralliart's Avatar
front sway bar
has anyone changed front sway bar and if you did was it a pain to do in garage or was it ok. i want to change mine to whiteline 26mm.
Old Feb 20, 2011 | 05:04 PM
jkennedy293's Avatar
Change the rear first, if you haven't done so already. Adding a thicker front sway bar without changing the rear will make the car push like a dump truck.
That being said, the front sway bar should be easier to change than the rear.
Old Feb 20, 2011 | 05:14 PM
sstevojr's Avatar
Actually the front is much more of a PITA. You have to drop the front sub frame, disconnect your steering column input (whatever the official name is), and unbolt your rear motor mount. The rear is simply dropping the sub-frame, can be done in garage, BUT ONLY IF YOU KNOW WHAT YOU ARE DOING.
I'm having 26mm front and rear sway bars, rear diff lock down, and rear control arm bushings installed next weekend (my rear camber is at like -2.5* right now from coilover install, not entirely comfortable, haha).
Old Feb 20, 2011 | 05:38 PM
yeah im getting the 26mm front and 24mm rear sway bar but could not find 26mm rear. thanks for that info beeing a PITA or not it will be done in the garage lol it will take a bit.
thanks and all the luck with your upgrades
Old Feb 20, 2011 | 05:45 PM
jan_ralliart's Avatar
is there a 26mm rear sway bar? it wasnt listed on whiteline s web site?
Old Feb 20, 2011 | 06:52 PM
i didnt see one on there only 24mm
