control arms ?
Old Feb 16, 2011 | 11:17 AM
canadaralliart's Avatar
control arms ?
wondering if there are any control arms for RA out or any in making would love to replace mine with something lighter.
thanks
Old Feb 16, 2011 | 11:24 AM
total0wnage's Avatar
I was just wondering the same thing yestarday, a google search didnt yield me any results except for urethane bushings.
Old Feb 16, 2011 | 01:25 PM
SudzRA's Avatar
Sub'd incase someone comes up with some good info here
Old Feb 16, 2011 | 03:22 PM
gaabbee's Avatar
Someone once said somthing about evo 8 or 9 control arms will fit...maybe razorlab can check for us since he has both cars...worth a try
Old Feb 16, 2011 | 03:39 PM
if they work that would be good, that way we have a big selection and we can find used parts.
Old Feb 17, 2011 | 03:25 AM
03chi-town0Z's Avatar
i've been measuring cars as they come into the shop and it would appear that the only ones that are compatible that i've found so far are the evo x front lca's
Old Feb 17, 2011 | 05:54 AM
so the front end is like evo x or just the control arm. is there anywhere on the web where we can check the part numbers for the control arms from RA to evox, 9, 8 to see if they would be the same
Old Feb 17, 2011 | 07:47 AM
the part numbers are different because the evo's are aluminum and the ralliart's are stamped steel.
i still need to get a set side by side to be exactly sure, but with my imperfect measuring in-between working on the cars i noticed like a 1/4" variation in the width of the arms but the front to back was always exactly the same. im not sure if it's the curvature of the arms that's throwing me off or if, in fact, they are slightly different
this would indicate, if my measurements were correct, that installing the evo's arms would add a good deal of negative camber to the setup and may have other issues that have yet to be found, though i would think a good suspension setup with a decent amount of camber adjustment could correct most of the difference
Old Feb 17, 2011 | 12:12 PM
majinfajita's Avatar
Seriously, how are you not a mod yet. 90% of non-GST Basemap-related answers are provided by you, and its a great benefit to the community
Old Feb 17, 2011 | 01:12 PM
my application has been turned in actually wish me luck
Old Feb 17, 2011 | 01:22 PM
2muchboost's Avatar
You can upgrade your Ralliart A-arms to the ones from an evo X. Makes a BIG difference!
I dont have them yet but Robbi-Spec has done this already
Old Feb 20, 2011 | 08:26 AM
are they just a simple bolt on or needs some tweaking to fit.
Old Feb 20, 2011 | 08:30 AM
The part, itself, would be a bolt-on installation, but I would highly recommend going in to a shop for an alignment after install.
Old Feb 20, 2011 | 08:47 AM
oh good ill run to the dealership and see the price for them when i get back from work next week thanks for that info.
Old Feb 20, 2011 | 10:11 PM
EricJ@AMS's Avatar
No need for that. They list for $457 each.
