Just ordered EBC redstuff, need rotors!
Old May 20, 2011 | 09:03 PM
lookitznite's Avatar
2009 Ralliart here. Just purchased EBC redstuff. part# below. I hope this is correct.
Front pads DP3954C - 87.25
Rear pads DP31407C - 87.51
Now my question is does anyone have a definite answer on which rotors I should get that will work well with these pads? Please provide links! Thank you very much.
Old May 20, 2011 | 09:11 PM
RideSober's Avatar
If you are looking for EBC rotors the part numbers are:
GD7336Performance Slotted/Dimple $268.86 GD1576 Performance Slotted/Dimple$155.33
Old May 20, 2011 | 09:16 PM
Thank you...confirm it will fit 100%?
Old May 26, 2011 | 07:37 AM
JUST TALKED TO THE GUY AT EBC SALES...HE SAID A TOTALLY DIFFERENT PART #.....I'M SO CONFUSED NOW...
EBC GUY FRONT PAIR - USR7379 - $185
EBC GUY REAR PAIR - USR7381 - $162
DOES ANYONE HAVE EBC ROTORS THAT FIT? AND CAN CONFIRM THE PART NUMBER PLEASE?! ALSO WITH PADS THESE ARE THE ONES I GOT...
Old May 26, 2011 | 08:10 AM
initial_d2k's Avatar
i would trust what is written on their site... at least if something goes wrong, you can say their site are misleading/wrong
Old May 26, 2011 | 04:07 PM
jcm308's Avatar
Check the brake guide thread https://www.evolutionm.net/forums/09...ake-guide.html
There has been a post with an email copy from EBC stating that there was a mistake on their site and EBC currently DO NOT make USR series rotors for the RA.
I was going through all this recently, bought pads and fluid. Started looking for rotors and was having issues, so I decided to go for NFSLancer's BBK instead
Old May 26, 2011 | 08:05 PM
RideSober's Avatar
I don't really mind being helpful, but if you are not sure, perhaps you might try and verify some things directly for yourself. EBC's information is known to be wrong, and there is plenty of information available on this forum from several different sources about EBC's misinformation.
If you want to purchase EBC rotors, you should really contact the Place For Brakes. They have sold them to others, and actually do know what will work. By the way, they will give you the same part numbers I provided above.
Also, if you research enough on this forum, you will find that at least a couple others on this board have already used those rotors on their cars.
Old May 27, 2011 | 04:56 AM
Thing is I did get the information from the guy....but he sounded very unsure. He gave me the following parts for the rotors for our car....
However other threads on this forum shows a different part#.
Front rotors GD7336 - 268.11
Rear rotors GD1576 - 155.33
Which makes it a bit confusing is all; if someone who has them and has them on please confirm.
Old May 30, 2011 | 08:33 PM
Heliart's Avatar
I would suggest you buy the rotors from some bigger places like Amazon (they have a fit check on their site for parts), so if they say the parts fit and they don't it'd make it alot easier to return them.
Old May 30, 2011 | 09:05 PM
RideSober's Avatar
Based on my own experience, I can tell you for certain that DRT Rotors will work for sure and work great with EBC Redstuff pads.
Old May 31, 2011 | 07:28 AM
Thats what i'm planning to do. I already ordered the DRT roters...the redstuff just came in..noticed in your sig. that you have ebc redstuff...
are these the correct ones you got as well?
Old May 31, 2011 | 07:33 AM
RideSober's Avatar
Yes, those are the correct PNs, and this is what I have installed on my car:
Centric/DRT Slotted Drilled
F 120.46078
R 120.46074
DP3954C Front Pads Redstuff
DP31407C Rear Redstuff
Old May 31, 2011 | 10:49 AM
npham455's Avatar
Any pics? Do you have upgraded lines as well?
Old May 31, 2011 | 05:16 PM
F 120.46078
R 120.46074
GREAT THANK YOU FOR YORU FEED BACK! I PURCHASED IT ARLEADY WITH DRT...BUT FOR SOME REASON ITS STILL ON HOLD WITH MY BANK? IT SAYS WAITING FOR AUTH FROM MERCHANT LOL....I CANT WAIT >_< i wanna get AMS break lines too as well...did you bleed and flush out your fluids ?
Old May 31, 2011 | 05:25 PM
Look up those parts on ebay...they are really much cheaper than ones at DRT-SPORT.COM!!! BUT TOO BAD I ALREADY ORDERED.. AS LONG AS IT FITS I'M HAPPY
