? Sway bar ?
Old Apr 22, 2012 | 10:06 PM
sette3's Avatar
Question ? Sway bar ?
i have a 2010 Ralliart sportback do i need booth front and back sway bars ?
White line says a rear sway bar is good enough ???
Old Apr 23, 2012 | 04:25 AM
jkennedy293's Avatar
You can be very happy with just the rear sway bar.
Old Apr 23, 2012 | 08:41 AM
bossssman38's Avatar
Yep, rear does wonders to the car from what I hear
Old Apr 23, 2012 | 10:25 AM
ColdNapalm's Avatar
Depends on how you want the car to handle. If you want it to handle like stock only with more stiffness then you will have to replace both. If you want less understeer, you can be just fine with the rear. Personally I like it with the 24mm rear and stock fronts.
Old Apr 24, 2012 | 08:41 PM
billyboy1's Avatar
just the rear really improved the handling - made it more neutral rather than excessive understeer!
eeweeks
May 25, 2016 09:21 AM
88888
Jun 29, 2013 09:29 PM
theblackbeast11
26
Apr 7, 2013 12:27 PM
5speedwtneed
12
Dec 21, 2011 06:54 PM
Sickdriver
14
Nov 9, 2010 08:08 AM
