Tire/Wheel
Tire/Wheel
I just bought some 215/45R-18 Kumho Ecsta 4X XL tires and am now looking for some wheels. I am concerned about what offset range I need to stay in. I was looking at these but wanted to see what others think about the offset.
18x8 +45 is about right...rears will need spacers probably...but the question is why you would use 215s on them as they are 8 inch wide. One would suspect that you could get at least a 225 in there if not 235. In anycase, around 45 is a good place to be for 18x8s.
On a side note...those look like konig deceptions which can be had for less unless you have a reason to go with tire rack over other sellers. Course the konigs do weight a bit more, but if you care about that, you may wanna go with the motegi racing SP10 which is a cast rim in the teens.
