Largest Possible Rear Wheel?
Old Apr 30, 2012 | 05:59 PM
chlucero's Avatar
I tried measuring today but I couldn't come up with an easy number. Does anybody know the max wheel size I can go in the back?
Old Apr 30, 2012 | 10:53 PM
ColdNapalm's Avatar
Seen 255s. I suspect that is about as far as you can go before you have to start doing more then some fender rolling.
Old May 1, 2012 | 10:45 AM
Zombie Killer's Avatar
What's after fender rolling? Pulling?
Old May 1, 2012 | 12:21 PM
nunyas's Avatar
if you feel the inside of your fender edge you'll notice there is a lip where the metal folds in towards the car. fender rolling is where you take that lip and finish folding it to give your tires and additional 1/4" to 1" of clearance (depending on the car). It allows you to bring the tires all the way out to the edges of the car; so you don't have that inset wheel look.
Pulling, is just what it sounds like. When fender rolling does not provide enough clearance, you need to pull the fender out a bit. Some people might call this "flaring", but it's more subtle than that. When done right, you can't tell that anything was done to make the fenders wider and provide more tire clreanance.
Old May 1, 2012 | 04:27 PM
sstevojr's Avatar
I run 265's front and back with only a roll in the rear; but a 255 is probably best for 9 out of 10 set-ups.
Old May 1, 2012 | 06:25 PM
chlucero's Avatar
okay here is the deal I want the largest wheel in the back with fenders rolled not flared. I was wondering if something like a 10.5+60(70,80,90,100+) would work
Old May 1, 2012 | 07:54 PM
nunyas's Avatar
I'm pretty sure that with that width and offset it'll be rubbing the inner suspension components...
Old May 2, 2012 | 10:11 AM
sstevojr's Avatar
10.5, HAHAHAHA! This isn't a Mustang
Old May 8, 2012 | 06:48 AM
03chi-town0Z's Avatar
Go check the 08 lancer show and shine section. There's a guy running 10's and another running 10.5's with minimal fender work. Granted they are both running 215 or 225 tires and look like they belong on vwvortex site rather than here...
Old May 8, 2012 | 06:29 PM
No, but the Evo can run a 10.5. Hell some guy around here has an 11.
Old May 8, 2012 | 08:35 PM
nunyas's Avatar
the evo also has wider fenders...
Haitham
Jun 11, 2017 03:34 PM
raz
29
Jan 1, 2009 11:18 AM
robjeff25
Apr 22, 2007 08:15 PM
5230EVO
Sep 28, 2006 07:24 PM
macca20042
04-06 Lancer Ralliart How To Requests / Questions / Tips
11
Mar 22, 2005 11:37 PM
