Alignment question
Old Jul 19, 2013 | 11:38 AM
FASTER345's Avatar
Alignment question
Hello all, I noticed my '10 RA starting to pull to the left slowly and over time. When I got new tires the car REALLY pulled to the left so I got an alignement. The 'before' print out showed all sorts of crazy numbers where it appears each wheel was pointing several degrees from where they should have been. Anyway, after the alignment the car still pulls left, although not as much as before. Is there a setting I can tell the alignment guy to use so this car will track straight? Everthing is where it should be according to the 'after' print out.
Thanks for any help.
Old Jul 19, 2013 | 12:22 PM
stfuad's Avatar
if caster camber & toe are all within spec grab a pair of wrenches and straighten your wheel
Old Jul 19, 2013 | 01:15 PM
FASTER345's Avatar
Everything appears within spec as per the allignment machine print out. And the steering wheel is straight. It's the car that is pulling to the left. If I don't touch the wheel the car starts to turn left as does the wheel, I can pull the wheel to center and the car goes straight but if I let go then the car and wheel both turn.
Old Jul 19, 2013 | 02:57 PM
neogeo64's Avatar
It might help to post print out sheet after alignment specs on here.
Where you driving on the new set of tires/wheels a while before the alignment?
1. The tires might be worn a certain way that it still pulls.
2. It could be they did not tighten bolts after alignment, might want to go back and tell them it still pulls.
Hopefully it's not a shady shop that "sets the toe and lets it go" ,then hands a bunk printout to customers (my friend told me his last employer did this).
Old Jul 19, 2013 | 03:42 PM
hiboost2.0's Avatar
Check your tire pressure. Are you on coils? If so you may have one side a tad higher than the other?
Old Jul 22, 2013 | 11:01 AM
FASTER345's Avatar
Tires were a day old when I got the alignment, in fact the new tires made the car pull more than the old worn out OEM Advans which prompted me to get the alignment in the first place. New tires are Michelin Primacy MXM4 225/45-18 on the OEM rims.
I am going to go back and see if this can get fixed, just wanted to hear from the forum in case there's something specific I can ask them to do.
Thanks for your responses and here's the 'after' report:
Old Jul 22, 2013 | 11:05 AM
FASTER345's Avatar
I have the stock suspension, the guy said he set all four tires to 32psi...but I should check. So maybe I can fix the alignment myself by adding some more air on one side? Would that 'straighten me out'? Thanks or the input!
Old Jul 24, 2013 | 06:06 PM
stfuad's Avatar
have you tried swapping the tires left to right?
Old Jul 24, 2013 | 06:48 PM
nunyas's Avatar
get camber bolts for the front. The fact that both your front wheels are leaning in the same direction is causing it to pull to the side...
Old Jul 24, 2013 | 09:42 PM
tencents's Avatar
is this common on our cars? coz my car is doing the same thing. I changed the front tyres 6 months ago and left outer edge went bold, right inner edge went bold. Having alignments after alignments, car just doesn't feel right and going straight. Just had one recently and same as OP described, hold steering it goes straight, let go and everything goes left, I just thought it was because of the road tilting left (Australia) for water drainage is causing this.
Old Jul 24, 2013 | 10:37 PM
neogeo64's Avatar
Here was my first alignment ever done on the car.
before (top) after (bottom)
If you look at the smaller #'s to the left and right of the bigger #'s those are the factory spec that they should be between.. your front caster and camber look like they are out of spec.
front camber factory spec between -0.50 to -0.70
front caster factory spec between 2.77 to 2.57
Old Jul 31, 2013 | 08:49 AM
FASTER345's Avatar
This may be a dumb question but how can my camber be so far off factory spec if there's no way to adjust it without buying aftermarket camber bolts? If I took this to the dealer and said look it's waaaay off spec would they replace a part for something since there's no adjustment possible without the currently non-present camber bolts? I want to take it back to the alignment place but I'd like to tell him to just get my camber the same on both sides so the car doesn't pull left...but from what I read here that's not possible without (third time I mention them I know) aftermarket camber bolts. Thanks guys for your help.
Old Jul 31, 2013 | 09:35 AM
neogeo64's Avatar
There is camber adjustment, its just limited. The strut bolt holes are oval shaped to allow for minor camber adjustment.
If you lower the car past 1.5":
Aftermarket bolts give you another deg or 2 of adjustment.
If you get coilovers , the front set usually have adjustable top hats to give you even more camber.
For the rear you need adjustable upper arms or press in aftermarket bushings to correct the camber if lowered.
EvoX267
11
Oct 1, 2015 11:08 AM
Kento240
15
May 2, 2012 12:42 PM
taylorgang
12
Feb 18, 2012 11:59 AM
nav06mr
14
Sep 15, 2010 04:57 PM
CLeeEvo
Aug 21, 2004 10:02 AM
