Wheel fitment question.
Im looking at getting new wheels. Right now I have 18x8 offset 43. The ones I want are going to be 18x9.5 offset 40 does anyone know how these will fit? I have bc coilovers and ive test fit a set of wheels that were 18x9 offset 25 they poked alot but the size was good.
You should be fine if you roll your real fender.
I have fit 18x9 +35 with 245/40/18 tires.
The 9.5 width at 40 offset makes the face of the wheel about the same on the outside but it is closer to the inner suspension components. I't should clear your B/C's but it will be close. I would not go wider then 245 tires or it might rub if wanting the correct camber specs.
Below is my wheel in orange that fits fine with rolled rear fender, green in your specs, same tire on both.
Rolling only will not work with those 245 tires and a large drop, Im tellin you now. I rubbed just on springs with 245s so a big drop will destroy his tires and/or fenders.
Oh I didn't put the wheel I was looking in the original post. The wheel im looking at is the miro type 111. They only come in 18x8.5 35 or 18x9.5 40. I was going with the bigger wheel but if I should go with the smaller wheel I will. Anybody heard anything about these wheels?
Richevo10
Jan 28, 2014 04:54 AM
EVOlution33
Jul 16, 2008 04:25 PM
KZEVO
13
Jan 31, 2004 10:19 PM
