I've sprung a leak!
Old Jul 15, 2009 | 07:20 AM
velocityhead's Avatar
Finally got my car back today; here's what they had to say:
We have removed the transmission and found that the end shaft seal is leaking between the engine and transmission. We have lifted the vehicle and inspected, found that the transmission is leaking, called Mitsubishi Tech Line (127955) and we were instructed to remove the transmission and send in picture, Mitsu received pictures and we were instructed to replace the end shaft seal, clean and reinstall, reinstalled, test drove and reinspected for leaks, no further leaks are detected at this time and the vehicle at this time performs to manufacturers specifications.
Old Jul 15, 2009 | 09:23 AM
Ladogaboy's Avatar
Right on! This might be something that all of us RA owners need to be mindful of. In your case, it was obviously a manufacturing or assembly flaw, but those types of seals are wear items. Definitely something to put on the checklist when doing maintenance inspections later in the car's life.
Old Apr 15, 2010 | 03:43 PM
gaabbee's Avatar
tranny oil leak
so i went under the car to do a regular oil change today and noticed some wet spots on the plastic cover before starting the oil change. I removed the cover and oil is leaking around my transmission. Anyone else notice this. Im completely stock and only had the car for 3k miles so far. It has around 10700 on it. help?
Old Apr 15, 2010 | 04:38 PM
Psycho09RA's Avatar
Arrow
Haven't heard of any tranny oil leak issues before. I recommend taking it to the dealership to find out what's up with it.
Old Apr 15, 2010 | 04:42 PM
RotorGlow's Avatar
Take it for warranty.
Old Apr 15, 2010 | 05:56 PM
gaabbee's Avatar
plan to thanks guys hope they dont give me shiiit about doing my own oil changes
Old Apr 16, 2010 | 12:21 PM
I had the same thing happen to me. I noticed the leak after about 1 month (1,200 miles). Ended up being a bad seal on the tranny.
https://www.evolutionm.net/forums/09...rung-leak.html
Old Apr 16, 2010 | 03:44 PM
Psycho09RA's Avatar
Shouldn't be a problem as long as you keep your receipts and keep record of when you did the oil change and what your mileage was at the time you changed the oil. At least that's what my dealership told me.
Old Apr 16, 2010 | 07:27 PM
jkennedy293's Avatar
Changing you engine oil should have zero effect on the SST leaking.
Old Apr 17, 2010 | 06:22 AM
gaabbee's Avatar
yea i agree but you never know with these stealerships right haha...appointments on tuesday
Old Apr 20, 2010 | 01:01 PM
gaabbee's Avatar
so they called me today and told me that they had to replace the transmission oil filter housing...should have it by thursday...
Old Apr 20, 2010 | 02:39 PM
03chi-town0Z's Avatar
yea, there's a bulletin on this. depending on how bad it is, just replacement of the cover and a re-seal with some heavy duty rtv type stuff. no biggie.
Old Apr 20, 2010 | 05:17 PM
gaabbee's Avatar
hope soo!!
Old Apr 22, 2010 | 02:12 PM
gaabbee's Avatar
got my car back this afternoon...they replaced the transmission filter bracket?? they said it was an external part so they didnt have to replace the whole unit...but i still got fresh new fluid for free
Old Apr 22, 2010 | 03:12 PM
toredefine's Avatar
Ok, I wanted to bump this old thread for a legitimate reason. I noticed a couple similar symptoms of the transmission leak problem, on my car. On my previous oil change, I noticed a small build up of oil on the plastic tray under my engine oil pan. I thought maybe I didn't tighten the oil filter on hard enough and it leaked a little. Then I remember NOT noticing any dried oil on the oil filter. I remember just shrugging it off and moving on. I don't know why I didn't find any of this alerting until now! So I made an appointment to have this checked. I'll update to let you all know what I find out.
