boost gauge help
Old Jul 21, 2009 | 06:09 PM
tjac357's Avatar
boost gauge help
I'm looking to install a boost gauge on my RA. was wondering how people who've done it got through the firewall and if there were any suggestions on a single a pillar pod. thanks for the help!
Old Jul 23, 2009 | 01:06 AM
tjac357's Avatar
please! i'm moving in to my college soon and would like to finish this before i go since i won't have the tools there.
Old Jul 23, 2009 | 01:13 AM
dxbtune's Avatar
From: I'm Canadian living and working in Dubai/Kuwait/Bahrain
All you need to do is get in on the passenger side and remove the plastic that is under the glovebox. Once that is done peel back the carpet a little and you will see a place where there is a wire loom comming in from the engine bay. Get yourself a coat hanger and pass it through so it goes into the engine bay side. Either from under or on top depending where you have more clearance tape the line to the coat hanger and pull it through into the cockpit.
If its an electrical line your running it will be easy, if your running a mechanical boost gauge and your running the boost/vacuum line then spray some wd-40 on the line so it slides through the rubber grommet more easily.
Old Jul 23, 2009 | 01:50 AM
speedie's Avatar
On my RA there was a rubber bung with nothing in it behind the lefthand arch. I had to remove the airbox to get in there
Old Jul 23, 2009 | 06:55 AM
jazket's Avatar
https://www.evolutionm.net/forums/ev...lean-hell.html
Old Jul 23, 2009 | 06:35 PM
speedie's Avatar
This is the one I'm Talking about
It enters the cabin behind the fuse box.
Old Jul 23, 2009 | 10:00 PM
tjac357's Avatar
thanks everyone! it seems like everything is piling up and i'm glad this is sorted out. now just waiting for the gauge
