ATF Fluid?
Old Dec 4, 2009 | 06:45 PM
slyman's Avatar
ATF Fluid?
What kind of fluid do I use that has a small canister in our trunk hidden behind the carpet on the right side? I am down to a minimum already and it says ATF on top of the cap. I know that ATF is related to automatic transmission fluid if I am not mistaken. What would you recommend? Although we have a twin clutch system and I am little confused here. Any help would be greatly appreciated.
Old Dec 4, 2009 | 07:28 PM
Psycho09RA's Avatar
The AWC uses ATF fluid, but more specifically Diamond ATF SP III. Not sure if any ATF fluid will do though, you may want to check with your dealership.
Also, on a side note, I have noticed that my AWC fluid is low only to find out the next day that the fluid level is fine.
Old Dec 5, 2009 | 12:50 AM
tjac357's Avatar
you have to drive around and check the fluid level right when you get out of the car or else it will be too high or low. my tech had me check mine for a month after he replaced my acd pump. nothing like starting a recall!
Old Dec 5, 2009 | 07:17 AM
07outty's Avatar
the method to check the level of the awc would be........
.........after driving the car. park it , turn it off , check the level after about 2 hours.
Old Dec 5, 2009 | 10:20 PM
tjac357's Avatar
no. my tech told me specifically to check it with the engine on after driving around for like 20 mins. it rises after it's been off for a while.
Old Dec 6, 2009 | 08:00 AM
07outty's Avatar
READ your manual.
check level 90 minutes MINIMUM after turning the car OFF.
Old Dec 6, 2009 | 02:14 PM
slyman's Avatar
Thanks for feedback, I'll be looking into it.
Old Dec 6, 2009 | 04:51 PM
xi's Avatar
xi
Mine is right at the max line after sitting there overnight and right at the min line after driving it.
Old Dec 6, 2009 | 08:22 PM
fireguy1578's Avatar
You can use Mobile One ATF fluid. The back lists the compatability and Mitsu fluid is listed. It was around $8 for a qt. of it at AutoZone.
boosted169
May 23, 2015 08:21 PM
tclelek
Apr 28, 2014 05:32 AM
matlark
Evo X How Tos / Installations
Apr 4, 2012 08:43 AM
pinoy6969
Dec 27, 2011 08:23 PM
EvolNinja
Jul 28, 2009 11:13 AM
