Help need stock ra turbo!!!!
Hey guys
bad news
well m,y turbo went bad, and
wont warrenty it due to my mods
I have seen that there are a few members on here who have already upgraded there stock RA turbos, I wanted to ask those fine members if any of you would be kind enough to sell me the stock turbo, please PM ME
bad news
Your turbo is dead? Hard to believe...
Have you done boost leak testing? It has the same effects as a blown turbo.
Maybe AMS has one for sale. I know they have a EVO X turbo for sale. You'll need the evo x manifold as well.
possibly. are all your vacuum lines in check? if your actuator isn't getting a boost signal then the turbo is operating off whatever the base spring pressure is in the actuator. (no clue what that is on the RA)
what problems are you experiencing for you to say that your turbo is shot?
more info is definetly required to help you troubleshoot.
Yes I know to. Turbo still spools just dosnt hold boost at all I have zero pounds of boost on wot. Car accelrates ****y. Seems as slow if not slower than a Gts. Me and my friend looked at it and he belives it's the wastegate. If it is I found a stock evo x wg for 80 bucks shipped. So if that's the case I will just do that.
keep us posted.. if yours went out good chance we will see more of these problems in the future... if this is a wastegate... do a official thread and may be mods will sticky it...
thanks...
thanks...
no boost sounds more like a leak in the plumbing. Go over all your connections starting at charge side turbo outlet. go over all those clamps. double check vacuum lines for cracks.
i've yet to look at the stock wastegate on these cars. I assume they're actuated like every other oem internally wastegated vehicle. with a actuator with a spring and diaphram? if so double check the actuator arm is still attached to the wastegate flap. this could be your problem since all your exhaust pressure would be going straight out the exhaust and not spinning your turbo to creat boost pressure.
Keep us posted.
Keep us posted.
