Help need stock ra turbo!!!!
Old Dec 5, 2009 | 10:06 PM
  #46
tre's Avatar
tre
Originally Posted by RallyGoneEvo
Thats your problem then. You should have a good amount of resistance when pulling the wastegate arm.
indeed. i'm not sure what the oem actuator is set for. maybe someone can chime in.
try disconnecting the vacuum hose to the actuator and attach your own hose and rig something up to supply pressure to it.. bike pump, compressor something. best would be even hookup a cheap pressure gauge between ur air source and actuator so u can see exactly how much psi your putting into it. if its opening the instant its seeing 1 or 2 psi i'd suspect your actuators is buggered.
Old Dec 6, 2009 | 07:20 AM
  #47
08Lancer89's Avatar
So you think the wastegate is bad? Anyone know the part number my dealer can't find It
Old Dec 6, 2009 | 09:17 AM
  #48
tre's Avatar
tre
the wastegate actuator.
but try and test it like i explained above before going back to the dealer to order one.
Old Dec 6, 2009 | 03:34 PM
  #49
08Lancer89's Avatar
Guesss what its fixed!
It was the ****ing vaccum line on the blowoff valve! Mists did not know their **** here wow they even tested for vac leaks
Old Dec 6, 2009 | 05:18 PM
  #50
DatRAzn's Avatar
^WOOT Congrats! Glad to hear you're up and running!
Old Dec 6, 2009 | 06:48 PM
  #51
silthos's Avatar
same here!!! Sucks bumming a ride to work.
Old Dec 6, 2009 | 07:36 PM
  #52
tre's Avatar
tre
awesome man! glad everything is fixed and operational.
Old Dec 6, 2009 | 07:50 PM
  #53
08Lancer89's Avatar
Thanks to all the memebers that gave me advice and help on tryin to solve my problem. Thanks alot.
Old Dec 6, 2009 | 08:08 PM
  #54
tjac357's Avatar
glad to hear everything got fixed!!
Old Dec 6, 2009 | 08:22 PM
  #55
K2Lancer's Avatar
Glad your back up and running. Thats almost as good as the Giants beating Dallas today.
Old Dec 7, 2009 | 06:17 AM
  #56
Bom's Evo's Avatar
You still going to get that evo x turbo? Can you sell it to me for $300 shipped?
Old Dec 7, 2009 | 01:06 PM
  #57
08Lancer89's Avatar
NOPE didnt order it
Old Dec 7, 2009 | 04:22 PM
  #58
Bom's Evo's Avatar
Can you share the source for the turbo?
