Static fuel pressure?
Old Dec 15, 2009 | 10:44 AM
tre's Avatar
tre
anyone know offhand what the static/idle fuel pressure is in the RA's?
also curious what the static pressure is on a EVO X.
ok now don't laugh as this may be a dumb idea. but i keep on thinking about SRI's and how they effect the overall a/f ratio's. Since its leaning out the entire table. would it not be a good idea to raise the static fuel pressure a bit to compensate? thinking this could be done with either a adjustable fpr. or depending on what the evo X is at idle. swapping their fpr if its compatible.
with the fpr you could either just run it to adjust static pressure or attach the vacuum line to it (thinking aeromtive 1:1) for boost refrence so its adding a bit more fuel pressure as boost increases.
thoughts? am i off my rocker?
Old Dec 15, 2009 | 11:52 AM
velocityhead's Avatar
A tune would be:
  • Cheaper
  • Safer
  • More accurate
Old Dec 15, 2009 | 12:20 PM
tre's Avatar
tre
Originally Posted by velocityhead
A tune would be:
  • Cheaper
  • Safer
  • More accurate
true...
was just running ideas in my head. but ty for not answering my questions
Old Dec 15, 2009 | 01:49 PM
Heh sorry
What you're suggesting sounds entirely possible. I could see this in use before we had these fancy ECU's, but nowadays it would be redundant.
Think how complicated things would get when the amount of fuel entering the engine is dependent on analog boost levels AND digital ECU fuel trims.
Old Dec 15, 2009 | 02:15 PM
tre's Avatar
tre
Heh sorry
agreed. was just thinking about how my old 1g turbo'd neon was setup. mind u i was using a rising rate regulator rather then a 1:1
was mainly thinking about intakes and lean conditions. and got me to wondering specifically about upping the static fuel pressure a touch to compensate. really curious what the RA static pressure is and EVO X is. looked under the hood today and the fpr mounts to the rail in the same manner the evo X does.
Dynotech Tuning
39
Dec 3, 2016 11:04 AM
nwa7265
Jun 8, 2012 01:32 PM
Evo8Emperor
May 15, 2008 06:28 PM
ghoonk
Apr 16, 2008 09:42 PM
dudical26
10
Nov 28, 2006 07:52 AM
