spark plug gap etc
Old Jul 31, 2010 | 11:28 PM
SOG RA's Avatar
spark plug gap etc
Has anyone replaced the stock plugs yet? Curious how difficult it is, I used to have a Ford and it was a nightmare on that. If you have changed them, whats the gap? I am also curious what plugs you guys have used/aftermarket?
Old Aug 1, 2010 | 12:20 AM
bulhas's Avatar
well in the ralliarts i highly suggest picking up new plugs as they are 1 step warmer than evo plugs
Old Aug 1, 2010 | 12:40 AM
Colt4g63's Avatar
Where is the cheapest place to pick up a set of X plugs? Stock 8 heat range. I know in 2010 they went to a 7 in the RAs and id like to go to an 8 now that i have the boost turned up etc. TIA
Old Aug 1, 2010 | 08:49 AM
EricJ@AMS's Avatar
The X style plug is still only available through Mitsubishi dealers. The 8 range plug is 1822A021 and they retail at 17.37 a plug.
Old Aug 1, 2010 | 09:04 AM
Colt4g63's Avatar
Which plug would you suggest?
Old Aug 1, 2010 | 10:53 AM
SOG RA's Avatar
^what he said.
Old Aug 1, 2010 | 11:08 AM
EricJ@AMS's Avatar
I would say the 8 range plug. But I wouldn't waste $70 on a lightly modded car just to go one range colder.
Old Aug 1, 2010 | 10:48 PM
SOG RA's Avatar
I have talked with a couple tuners, Mellon for instance requests that all the spark plugs be changed out before switching the tune. This is using the logging method with Access tuner software and sending info to him so he can tune the AP. Does he request this just to make sure, without a doubt, that the car is firing properly for the new tune, or is it a safe play to change them whenever getting a more aggressive tune?
Old Aug 1, 2010 | 11:18 PM
Colt4g63's Avatar
As a tuner myself i would say both. It's frustrating having customers come over for a tune and there plugs are shot... they have a boost leaks, there wide band isn't hooked up and the list goes on.
Old Aug 2, 2010 | 12:34 AM
SOG RA's Avatar
So, that being said, how hard is changing out the plugs on our cars? I do most of my own work and as long as they arent going to break off like they did in the Fords I owned, I should be fine.
Old Aug 2, 2010 | 01:02 AM
Colt4g63's Avatar
Its IMO one of the easiest maintenance procedures on our cars....
Old Aug 2, 2010 | 10:15 AM
Magnus82's Avatar
I just ordered a set of X plugs to replace my stock ones. I've checked the plugs a couple of times and it wasn't difficult pulling the plugs and putting them back in..... and I know next to nothing about working on cars.
I'm also assuming that since the X plugs are OEM plugs that I shouldn't have to gap them.
Old Aug 3, 2010 | 10:26 AM
toredefine's Avatar
Where did you buy the plugs at? And what is the part number?
Old Aug 3, 2010 | 10:55 AM
Magnus82's Avatar
mitsubishiparts.net
Spark Plugs NGK ILKR8E6 1822A021
I think you can get them from AMS too.
Old Aug 3, 2010 | 11:35 AM
SOG RA's Avatar
Ok so the stock evo x plugs and ralliart plugs are exactly the same right
