COBB Access port
Old Aug 5, 2010 | 04:56 AM
mcw320's Avatar
COBB Access port
Does any have it? I'm thinking about getting my ecu reflashed. What's are the pros and cons of that ?
Old Aug 5, 2010 | 05:52 AM
Gibby860's Avatar
If u looked 3/4 page down, there is a Cobb section and 1/2 down there is a poll for GST VS Cobb. Some good info. I also found that HB speed has done maps for Cobb and 260 hp & 296 Tq with 91 oct - Boost pill and Test pipe.
http://www.hbspeed.com/dyno/graph.ph...rgb3=000153000
h4ckluserr's Avatar
good place to start is the search function, then try google, if you can't find the info in those locations, sell your car.
Old Aug 5, 2010 | 06:33 AM
jkennedy293's Avatar
The mods should look into not allowing users with less than "x" amount of posts start new threads. I think this would solve alot of the problems with uneccesary threads.
Just my two cents.
Old Aug 5, 2010 | 06:50 AM
lchu's Avatar
Just a quick question, does it matter where I get a Boost Pill? Are all the Boost Pill the same?
Like the UR Boost Pill vs the GST Boost Pill etc...
Thanks in advance
Old Aug 5, 2010 | 07:15 AM
Thanks in advance
All boost pils are not created equal. Use the boost pill from whoever supplies the base tune. So if you use the GST base map, use the GST pill.
