another maf/bov question
I was reading the new super street issue and there was a guy on there talking about converting a MAF to a MAP and I am under the impression this allows a car to run a VTA BOV without all the issues. Does anyone have any experience with this?
https://www.evolutionm.net/forums/09...n-70-00-a.html
No need to go through all that trouble. Run an open element intake and you'll achieve the VTA noise you desire.
Not only that but I am reading a MAP is more accurate than A MAF especially in FI engines. I read some nissian forums where they removed the MAF and drilled a spot on the upper intercooler pipe to install a MAP but I have no other info than that such as wiring and etc. I am guessing this is not an easy task since there are no replies.
