Ralliart SST cluth kit
Old Feb 22, 2011 | 11:05 PM
Malaxa's Avatar
It is known that both the Evo X and Ralliart SST gearboxes have a common enemy.
This enemy is torque. High torque requires a better clutch.
What are the options for replacing the clutch?
Old Feb 22, 2011 | 11:39 PM
Rocky_RA's Avatar
http://www.sspperformance.com/produc...Path=33_39_110
South side performance is the only option, the best too!
Old Feb 22, 2011 | 11:54 PM
Malaxa's Avatar
Are you sure that you can use the Ralliart.
I saw these products, we saw the Buschur ...
I saw someone that they are specific for Ralliart.
Old Feb 23, 2011 | 01:37 AM
Rocky_RA's Avatar
Yes 100% sure! E-mail them and get all the info you can
Old Feb 23, 2011 | 09:18 AM
Malaxa's Avatar
Thanks, it was confirmed.
Old Feb 23, 2011 | 03:27 PM
RalliX's Avatar
Our cars should hold up to ~300 ft-lb of torque at the wheel.
Are you going for a bigger turbo setup?
If not, you are safe with our stock turbo.
Old Feb 24, 2011 | 03:09 PM
bsvaton's Avatar
clutches work fine on the RA
Old Mar 2, 2011 | 12:51 PM
Malaxa's Avatar
Thanks for the info!
Old Mar 2, 2011 | 02:03 PM
sstevojr's Avatar
This enemy is BAD DRIVERS. High torque requires a better DRIVER.
What are the options for reTRAINING the DRIVER?
FIXED!!
I don't consider torque to be the enemy (I love torque, thats my DD realm), I consider the lack of the driver mod to be the enemy of the tranny. And FYI, the slipping is shown to start at 346 wtq (its part of the ecu decoding that has been going on around here). So as long as you limit it to 330ish, you will be fine. But then again, you could have 280 wtq, drive live a douche, and destroy ur tranny (re: first point made )
Old Mar 2, 2011 | 07:48 PM
newmitsuowner's Avatar
Originally Posted by sstevojr
FIXED!!
explain to me how someone would drive like a douche? im very serious about this question. i almost always drive in normal mode, there is a few times where i let the beast go and use automatic sport. yeah sometimes i do floor it but actually i havent gone to top speed yet. need a nice day on the highway to try it out. i hit 100mph and noticed i could go more, because the pedal still had some more room for me to push it in more.
Old Mar 2, 2011 | 07:55 PM
pbassist12's Avatar
Wouldnt it depend on how much mods you got?
Like replacing the clutch after you have a lot of mods
Old Mar 3, 2011 | 05:43 PM
Slee256's Avatar
Originally Posted by newmitsuowner
explain to me how someone would drive like a douche?.
Giving it heavy throttle in a high gear at a low RPM=driving like a DB, and it's a quick way to burnout your transmission.
Old Mar 3, 2011 | 11:29 PM
lookmanohands's Avatar
And that is why when giving it the beans in auto mode it kicks down a gear to help you from wrecking ur tranny
Old Mar 4, 2011 | 07:21 AM
initial_d2k's Avatar
I guess you just have to make sure you dont floor it if the RPM is lower than 3000...
on highway i make sure to lower to 4th or at least 5th before stepping on it... not to mention it sounds better =)
Old Mar 4, 2011 | 08:02 AM
chazyronnie's Avatar
Ralliart loves to rev!!!
