Ralliart Synapse DV question
Old Apr 2, 2011 | 12:28 PM
Psandman's Avatar
Has anyone of you out there with a Ralliart tried the Synapse DV to replace your OEM plastic DV? If so how did you set it up (push, pull, a, b, or both) and did you have any problems with it?
Old Nov 23, 2018 | 10:11 AM
Laza's Avatar
Sorry to wake up this thread from years ago..
I've run the Synapse on my RA for years, until it broke (pre-load spring broke and made the BOV stick). Now I have a repaired one, but I've yet to find the perfect adjustment. The closest I've gotten is in the video below, with ports A+B connected and pre-load spring all the way out:
At lower speeds + WOT it actuates perfectly, but in the mid-range I get this flutter (when I let off the throttle more gently). It doesn't sound too good in my opinion, but I don't know how I should adjust it from here on :-/
