what would happen if i lowered my boost to zero
Old May 12, 2011 | 08:45 PM
2010 Rallihead's Avatar
I recently lower it from 25 to 16psi and saw the mpg go from 18 city mpg to 28 mpg, I'm thinking of dropping it to 9psi or even zero, would this effect the vehicle anyway?obviously i be less HP that that's agiven if i could possibly reach 30 mpg
Old May 12, 2011 | 09:19 PM
initial_d2k's Avatar
I have always wondered if we can "shut down" the turbo when we want it =P... i wonder if thats the samething as staying out of boost all the time...
Old May 12, 2011 | 10:42 PM
RonPattonJr's Avatar
I'm curious by this, quite interesting as I was wondering a similar thing.
Old May 13, 2011 | 12:01 AM
adog's Avatar
Originally Posted by ronpattonjr
i'm curious by this, quite interesting as i was wondering a similar thing.
+1
Old May 13, 2011 | 12:16 AM
Ok well when i wake up ill try it on 0 for alil while and report back... something tells me its not gonna stay at completly 0... but hopefully it does work... I tried staying out of boost (staying in hight numbersof vaccum) but noticed if I hit lower vaccum numbers it was giving me almost the same mpg as if I were in lower boost, like 1-5psi
Old May 13, 2011 | 12:30 AM
richardjh's Avatar
If it helps, as part of some tuning/experimenting, I set my BaseWGDC table to all zeroes. I was checking wideband AFR readings in the "middle" of the map
When driven WOT, that gave me about 9.5psi - with AMS Boost Pill installed.
I was thinking of repeating the "all zero" thing with the stock pill - see what that gives me at WOT.
Rich
PS. 9.5psi is very boring.
Old May 13, 2011 | 06:24 AM
gloom's Avatar
This is exactly what I wanted for a long time and its possible to even change maps on the fly with tephramod. I dont think mpgs are interesting for most guys here though lol.
Ralliart is a better DD then the Evo X so I would assume it would be more interesting but meh, I dunno.
Old May 13, 2011 | 06:37 AM
Mad_SB's Avatar
Rich
You won't get less than wastegate spring pressure which I would have thought would be 11psi sounds like your actuator may be lacking some preload. Only other option would be to hang the wastegate flapper open... that would limit the boost as much as possible.. probably still see a psi or two.....
Old May 13, 2011 | 06:41 AM
Piper747's Avatar
I think our stock wastegate is only about 7 psi. I could be wrong...
Old May 13, 2011 | 07:05 AM
richardjh's Avatar
With all-zero BWGDC table, the boost reading touched 10.6psi around 3000rpm. It then settled back to 10psi, and tracked ever-so-slightly lower from there... 9.6psi at 5000rpm.
I can't tell you what it did after that - I fell asleep!
Nerfing the BWGDC table is a fairly handy trick for tuning certain areas of the fuel map, but for "driving economy", you can surely do what you need to by keeping the ol' throttle foot under tight control. Assuming that's even possible...
Rich
Old May 13, 2011 | 07:23 AM
gloom's Avatar
If its possible to change where the boost kicks in that would be even better
Old May 13, 2011 | 08:26 AM
Agreed, but atleast we have a way to limit the max of the boost love messing around the controller I'm gonna drive to work and see what the mileage im geting with the boost controller turned all the way off as possible.. lol Ill be a granny on the freeway with just my 2.0 cracking
Old May 13, 2011 | 09:49 AM
freeagent3117's Avatar
Haha just trade it in for a GTS for better mpg lol.
Old May 13, 2011 | 09:56 AM
Why do that when i can have the same gas mileage. And when i need the power I just turn the boost controller
Old May 13, 2011 | 10:00 AM
I tried lowering the boost all the way but when I do it doesn't go to zero, its stays around 9-10psi iono how to make it go any lower..
