afr
Old May 22, 2011 | 11:53 AM
RalliMark's Avatar
afr
I just installed my wideband and was curious what normal afr readings are while just cruising and letting off the throttle and coasting. I searched but really didnt find anything.
Old May 22, 2011 | 12:07 PM
RazorLab's Avatar
During cruise, idle, very light throttle it will bounce around 14.7.
On decel it will be full lean, 20
Old May 22, 2011 | 12:22 PM
RalliMark's Avatar
Thanks man just making sure it was supposed to lean that much.
Old May 22, 2011 | 03:23 PM
ArtofRalli's Avatar
What company did you go with to buy the wideband?
was it easy to install?
Old May 22, 2011 | 06:06 PM
richardjh's Avatar
On my vehicle (modified GST base map, boost pill)...
When I let off the throttle, I'll get a brief rich spike followed by either a total fuel-cut or a map-lookup-based trailing fuelling around 12.8:1. The ECU decides which by tossing a coin, I think.
When I initially increase throttle, I'll also get a brief rich spike.
As Bryan said, on light throttle cruising - and even light-throttle accelerating - you'll stay in closed loop, and bounce around 14.7:1. With restraint and careful throttle control, it's possible to drive around all day in closed loop.
Rich
Old May 23, 2011 | 05:37 PM
RalliMark's Avatar
I bought an AEM Eugo of the boards used. It was easy to install. I have a friend with a X that already installed his and has the same a pillar I have too so it made it super simple. There are how tos on how to install them also.
Old May 23, 2011 | 05:40 PM
richardjh's Avatar
Got logging from it too?
If it's got 0-5V analogue, you can connect that straight into pin 8 of the Taxtrix OP2.0 and log in standalone mode.
Rich
